Member: 484060
Sonork: 100.1596821 Thanks Meter: 406 | Quote:
Originally Posted by pradeep_kus you are useing old varison
now flash with this varison | i am tery new ver but same by mxkey Quote:
MXKEY [FT SCR2000 0], SN: C0811426
Using device: USB ROM
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.70
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
Processing MCU file: RM-718_025.007_79.92_prd.core.fpsx
[BB5,XSR 1.6] size: 108.26 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 21113A19
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 26100215EED50344E4453C26664D31C8AFF2B62F
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0068 - 0000 0131 [Samsung LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x178 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35375904021998_CE RT.rpl).
CMT PAPUBKEYS HASH: C436DE8B3DEA6D6C6CCE9CBE15F7C501BB822D02
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning....
Partitioning complete
Erase size: 474.56 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-0DAFFFFF]
CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: C436DE8B [RAP Certificate 221 Ver] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 19.875 s
Processing PPM file: RM-718_025.007_01.01_EURO1_79.92_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 49.29 MB
Erase size: 59.25 MB
CMT FLASH,MuxOneNAND area [090C0000-0CBFFFFF]
CMT SOS+ROFS2 block sent
Programming completed in 8.812 s
Processing PPM file: RM-718_025.007_00.01_79.92_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 4.80 KB
Erase size: 15 MB
CMT FLASH,MuxOneNAND area [0CC00000-0DAFFFFF]
CMT SOS+ROFS3 block sent
Programming completed in 0.062 s
Processing CNT file: RM601_APE_ONLY_ENO_11wk15_PS2_v0.063.fpsx
[BB5,XSR 1.6] size: 4.73 MB
Erase size: 5 MB
CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF]
CMT SOS*ENO block sent
Programming completed in 0.828 s
Total time for flashing process(boot+erase+write) was 45.079 s
Waiting for device boot up ...
Phone not found, retrying ...
Aborting operation ...
| by aft box Quote:
Number of Image Files: 4
Processing Image File :
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 13000000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 457
Entry Point: 0x0211
Page Format : -1
MAX PAGE : 0x00040000
CMT Type : BB5
Number of Blocks : 2
Entry Point: 0x00EB
Page Format : -1
MAX PAGE : 0x00000E00
CMT Type : BB5
Number of Blocks : 199
Entry Point: 0x00F1
Page Format : -1
CMT Type : BB5
Program Sending Speed : 6500000Hz
Number of Blocks : 20
Entry Point: 0x0135
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
If Flashing DOES NOT Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
BootRom Verified!
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 600C1921
ID DWORD 4 : 02031104
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00001040
3 EM_ASIC_ID 02
ID DWORD 0 : 00001030
4 PUBLIC_ID 12
ID DWORD 0 : 26100215
ID DWORD 1 : EED50344
ID DWORD 2 : E4453C26
ID DWORD 3 : 664D31C8
ID DWORD 4 : AFF2B62F
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : E693EF0D
CRC 1 : AC22615B
START FLASHING
RawLoaderExtract: RM-718_025.007_79.92_prd.core.fpsx
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2n d.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0068 -> Type not in database
Revision ID : 0131
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data :
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Flash Descriptor
Device ID : 0068
Revision ID : 0000
Size : 40000000 (1024 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XS R17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
START READING RPL DATA
IMEI: 353759040219986
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
Reading : PARTNERC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\353759040219986\3537590402199 86_91714.rpl
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
ImagePath: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-718\
ImageFilename: RM-718_025.007_79.92_prd.core.fpsx
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000020000FFFFFFFF00000005000000030000 00020014000002D80000000000040000000202EC00000AC400 0000000008000000010DB00000206000000000002700000001 2E100000105000000000000A000000013E60000000400000C0
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x57 (87)
ERASE Blocks : 0x02 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x23 (35)
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
0 : 00040000-0007FFFF
1 : 000C0000-008BFFFF
2 : 00DC0000-0DAFFFFF
3 : 2E100000-3E5FFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x03000000
Format Info : 000000000000000A0000000000000002000000640018000000 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5004120B000300000400000007FFFF120B000300000C000000 8BFFFF120B00030000DC00000DAFFFFF120B0003002E100000 3E5FFFFF6E
FORMAT_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000 00020000006400180000000000020000000100000000000000 0025
Successfully erased..
Total blocks to write : 457
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : SOS+PMML
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : LDSP
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
ImageFilename: RM-718_025.007_00.01_79.92_prd.rofs3.fpsx
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 0CC00000-0DAFFFFF
ERASE_REQUEST_BB5 : 5001120B0003000CC000000DAFFFFF58
Total blocks to write : 2
>> CMT Rootkey Hash CERT : SOS+ROFS3
ImageFilename: RM-718_025.007_01.01_EURO1_79.92_prd.rofs2.fpsx
StartErase_DCT5...
Device Index : 0x00
0 : 090C0000-0CBFFFFF
ERASE_REQUEST_BB5 : 5001120B000300090C00000CBFFFFF00
Total blocks to write : 199
>> CMT Rootkey Hash CERT : SOS+ROFS2
ImageFilename: RM601_APE_ONLY_ENO_11wk15_PS2_v0.063.fpsx
StartErase_DCT5...
Device Index : 0x00
0 : 008C0000-00DBFFFF
ERASE_REQUEST_BB5 : 5001120B000300008C000000DBFFFF79
Total blocks to write : 20
>> CMT Rootkey Hash CERT : SOS*ENO
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000001
Additional Bad : 00000001
Correctable ECC : 00000000
FlashInfo.RestartMode : 1
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:17
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Elapsed Time: 5 Seconds...
Elapsed Time: 10 Seconds...
Elapsed Time: 15 Seconds...
Elapsed Time: 20 Seconds...
Elapsed Time: 25 Seconds...
Elapsed Time: 30 Seconds...
Elapsed Time: 35 Seconds...
Elapsed Time: 40 Seconds...
Elapsed Time: 45 Seconds...
Elapsed Time: 50 Seconds...
Elapsed Time: 55 Seconds...
Elapsed Time: 60 Seconds...
Elapsed Time: 65 Seconds...
Elapsed Time: 70 Seconds...
Elapsed Time: 75 Seconds...
Elapsed Time: 80 Seconds...
Elapsed Time: 85 Seconds...
Elapsed Time: 90 Seconds...
Elapsed Time: 95 Seconds...
Elapsed Time: 100 Seconds...
Elapsed Time: 105 Seconds...
Elapsed Time: 110 Seconds...
Elapsed Time: 115 Seconds...
Elapsed Time: 120 Seconds...
Elapsed Time: 125 Seconds...
Elapsed Time: 130 Seconds...
Elapsed Time: 135 Seconds...
Elapsed Time: 140 Seconds...
Elapsed Time: 145 Seconds...
Elapsed Time: 150 Seconds...
WARNING: Phone is not in the Required Mode...
Disconnect the Phone and Power it Up Manually.
| but same problem not response |
