Old 11-27-2014, 08:57   #1 (permalink)
Member: 133116
Nokia c7 auto restart
Nokia C7 after restart after inserting sim card. Without Sim working fine. Also restart on emergency call without sim card.
Old 11-27-2014, 09:11   #2 (permalink)
helpful-man's Avatar
Member: 1306751
Sonork: 100.1604993
Thanks Meter: 4,916
replace pa problem 100% solve
Old 11-27-2014, 09:33   #3 (permalink)
Member: 844067
Thanks Meter: 2
change on off switch
Old 11-27-2014, 09:44   #4 (permalink)
Member: 2176135
Sonork: 100.1591520
Thanks Meter: 28
try this bro... one bye one its will work ok good luck
Old 11-27-2014, 10:19   #5 (permalink)
Member: 133116
same problem
@helpful-man-- changed PA ic same problem.
Old 11-27-2014, 10:20   #6 (permalink)
Member: 133116
@irfan gsm
Please post what has to be tried.
Old 11-27-2014, 10:52   #7 (permalink)
Member: 1759693
Thanks Meter: 54
@irfan gsm
Flash with latest version flash file bro.
Old 11-27-2014, 12:15   #8 (permalink)
Member: 2176135
Sonork: 100.1591520
Thanks Meter: 28
@irfan gsm
first remove black coil if same then change that ic.. its tested brother
Old 11-28-2014, 11:48   #9 (permalink)
Member: 133116
same problem
@irfan gsm
did as u said removed the coil and after that replaced the ic also but same problem
auto off on doing emergency call 112 and auto on inserting sim
Old 11-28-2014, 12:06   #10 (permalink)
Member: 1759693
Thanks Meter: 54
@irfan gsm
Bro I said did u try the software first. Normally u need to try the software first. To reduce the lost of handset.
Old 11-28-2014, 12:31   #11 (permalink)
Member: 133116
Already tried software... complete erase and flash
changed pa ic .. also changed ic near pa
and changed the big coil inside the shieled beside pa section and changed the ic in that section also.
Old 11-28-2014, 12:32   #12 (permalink)
LOKEMUNFU's Avatar
Member: 2100013
Thanks Meter: 125
@irfan gsm
Phone fails, we must first try FLASHING
If the problem is unchanged
This is the time to check the hardware
Old 11-29-2014, 14:28   #13 (permalink)
Member: 133116
@irfan-gsm
Page generated in 0.23217 seconds with 9 queries
