Old 05-05-2011, 14:53   #1 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,976
nokia c7 hardware solution here .
nokia c7 usb not charging solution
1. Try to use another USB charger and another known good PC or laptop.
2. Visually check the USB dock connector, clean, rework or replace if damaged.
3. Check the fuse and diode for possible open and short circuit.
4. Check the two resistors near the VBUS IC, it has a 510 ohms resistance value. replace if damaged.
5. Rework or replace the VBUS IC.
The Following 4 Users Say Thank You to aZimBahar For This Useful Post:
Old 05-05-2011, 14:55   #2 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Nokia C7 Not Charging Problem via Wall Charger Solution
1. If the phone doesn't charger, try to use another wall charger.
2. Check the battery or try to replace it.
3. Clean the battery connector or terminal.
4. Check the DC jack charging pin connector. Replace if damaged.
5. Clean the DC jack PCB contact pads.
6. Check the fuse and the diode for possible open and short circuit.
7. Trace the Charge In voltage and ground line paths.
8. Rework/replace the Charging switch controller IC.
The Following 3 Users Say Thank You to aZimBahar For This Useful Post:
Old 05-05-2011, 14:55   #3 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Nokia C7 Earpiece speaker problem solution
Hints in repairing Nokia C7 ear speaker problem:
1. Visually check the earpiece speaker for possible damaged, like misaligned terminals.
2. Clean the speaker terminal contact pads on the flex cable.
3.Check the earpiece speaker using a multimeter, replace if damaged.
4. Check the flex ribbon cable for possible damaged, try replacing it.
5. Clean the flex pin connector if oxidized.
6. Check/replace resistors and capacitors near the pin connector.
This are the basic repair procedures only. The high level solution will be posted for update.
The Following 2 Users Say Thank You to aZimBahar For This Useful Post:
Old 05-05-2011, 14:56   #4 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Nokia c7 Sim card pin connector jumper ways Solution
Applying a jumper wire on it is a little bit tricky but so easy, just use a magnifying glass to ensure the quality of solder and avoid short circuit.
Old 05-05-2011, 14:56   #5 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Nokia C7 Touch Screen Problem Solution
Check the touch screen panel assembly for possible damaged, cracked or broken. Check the touch screen flex cable, there is an IC mounted on it. managed to rework it.
If the touch screen still doesn't work, check the pin connector, clean if oxidized. Check or replace the resistors coils and capacitors.
The Following User Says Thank You to aZimBahar For This Useful Post:
Old 05-05-2011, 14:56   #6 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Old 05-05-2011, 14:57   #7 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
The Following 6 Users Say Thank You to aZimBahar For This Useful Post:
Old 05-05-2011, 16:23   #8 (permalink)
Member: 1320284
Thanks Meter: 16
very good job keep it up.
The Following 2 Users Say Thank You to jerryl27 For This Useful Post:
Old 05-06-2011, 06:46   #9 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
The Following 8 Users Say Thank You to aZimBahar For This Useful Post:
Old 05-08-2011, 05:57   #10 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
enjoy .
Old 05-26-2011, 16:17   #11 (permalink)
Member: 494907
Thanks Meter: 2
Good job thaks. verry helpfull
Old 05-27-2011, 12:58   #12 (permalink)
Member: 1536752
Sonork: an2nijohn
my nokia c7 does not on and not charging...i need help plz
Old 06-04-2011, 07:58   #13 (permalink)
Member: 1001744
Thanks Meter: 6
Originally Posted by azim bahar View Post
sir i hv nokia C7 and it doesnt on......... wt shud i do?
The Following 3 Users Say Thank You to sharif593 For This Useful Post:
Old 08-04-2011, 09:57   #14 (permalink)
Member: 274803
Thanks Meter: 23
i have nokia c7 only flash light on but not powr on any sloutation ??????
The Following User Says Thank You to aloksoni For This Useful Post:
Old 08-25-2011, 07:39   #15 (permalink)
Member: 720411
Thanks Meter: 14
i have a nokia c7. water damage after clen.now power ok but lcd white and hot. please anybody help me plzzzzzzzzzzzzzzzzzzzzzzzzzzzz.
Page generated in 0.20041 seconds with 9 queries
