11-25-2007, 17:18 | #1 (permalink) |
Major Poster Join Date: Jul 2007 Location: pakistan Age: 47
Member: 554070 Status: Offline Thanks Meter: 314 | Nokia Code function Nokia Code function *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5% #3370# Deactivate Enhanced Full Rate Codec (EFR) *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time *#4720# With this Nokia code you can deactivate the Half Rate Codec *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type *#9999# Phones software version if *#0000# does not work *#06# For checking the International Mobile Equipment Identity (IMEI Number) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) *#147# This lets you know who called you last (Only vodofone) *#1471# Last call (Only vodofone) *#21# This phone code allows you to check the number that "All Calls" are diverted to *#2640# Displays phone security code in use *#30# Lets you see the private number *#43# Allows you to check the "Call Waiting" status of your cell phone. *#61# Allows you to check the number that "On No Reply" calls are diverted to *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to *#67# Allows you to check the number that "On Busy Calls" are diverted to *#67705646# Phone code that removes operator logo on 3310 & 3330 *#73# Reset phone timers and game scores *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible *#7760# Manufactures code *#7780# Restore factory settings *#8110# Software version for the nokia 8110 *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again *#94870345123456789# Deactivate the PWM-Mem **21*number# Turn on "All Calls" diverting to the phone number entered **61*number# Turn on "No Reply" diverting to the phone number entered **67*number# Turn on "On Busy" diverting to the phone number entered 12345 This is the default security code press and hold # Lets you switch between lines The Operating Systems Symb OS v6.1 Nokia 7650 Nokia 3650 Nokia 3660 Nokia N-Gage Nokia N-Gage QD Siemens SX-1 Sendo X Symb OS v7.0 Nokia 3230 Nokia 6600 Nokia 6620 Nokia 6260 Nokia 6670 Nokia 7610 Panasonic X700 Panasonic X800 Symb OS v8.0 Nokia 6630 Nokia 6680 Nokia 6681 Symb OS v8.1 Nokia N70 Nokia N90 Symb OS v9.1 Nokia N91 Nokia 3250 Nokia E60 Nokia E61 Nokia E70 Nokia N71 Nokia N80 Nokia N92 Nokia phones service codes *#0000# - SW version *#06# - IMEI *#war0anty# - SIMLOCK info *3370# - Enhanced Full Rate ON #3370# - OFF *4720# - alternative sound quality codec ON #4720# - OFF *#7780# - default factory settings *#7760# - production serial no. *#2820# - Bluetooth info. Samsung T309 and T809 100% No need to use BOX 1st Make Full Eprom Reset *2767*3855# After Rebooting Mobile then enter... *7465625*638*00000000*00000000# (to change NCK code to 00000000) then enter... #7465625*638*00000000# (to permanently unlock the phone) check the lock status... *#7465625# *#73# - reset phone timers and game scores. *#7370925538# - delete all the content of the wallet and the wallet code. *#7370# - soft format — erases all telephone memory. [Green]*3 - hard format — if only the telephone memory is formatted, puts back the attitudes and reboots *#delset# - MMS/GPRS settings removal NOTE: code depends on phone model. Samsung D500 openline *7465625*638*00000000*00000000# NEXT ENTER #7465625*638*00000000# :#7465625*638*KEY2# Sanyo 200 Codes To enter codes dial the code just like any other phone number | ##786# - Phone Usage & Master Reset (##RTN#) | ##33284# - Debug Menu Sanyo VI-2300 Codes To enter codes dial the code just like any other phone number | ##786# - Phone Usage & Master Reset (##RTN#) | ##3282# - Data Provisioning (##DATA#) | ##33284# - Debug Menu Known Issues The Sanyo VI-2300 cannot be used as a modem. Sanyo made minor modifications to this phone's modem protocol, and have refused to publish the drivers for the device to be used with a computer. Sanyo VI-2400 Sanyo 4700 Codes To enter codes dial the code (just like any other phone number) then press the OK key and select "Save Phone #" from the menu | ##786 - Phone Usage & Master Reset (##RTN) | ##3282 - Data Provisioning (##DATA) | ##040793 - Modify phone's data speed, the built-in cap. Changing the phone to 144/230 mode can improve speed over the default setting of 144K, as it removes the phone's built-in cap Hacks Sanyo 4900 > 7200 Hack The Sanyo 4900 and 7200 use almost identical hardware, if not exactly identical on the inside. Because of this, the firmware is interchangeable. This will even enable ReadyLink on the 4900. To do this you pretty much need to be a Sprint Store technician, as most TSRs will refuse to do the firmware swap. Sanyo RL-4920 Codes To enter codes dial the code just like any other phone number | ##786# - Phone Usage & Master Reset (##RTN#) | ##3282# - Data Provisioning (##DATA#) | ##33284# - Debug Menu Sanyo 5150 Codes To enter codes dial the code (just like any other phone number) then press the OK key and select "Save Phone #" from the menu | ##786 - Phone Usage & Master Reset (##RTN) | ##3282 - Data Provisioning (##DATA) | ##040793 - Modify phone's data speed, the built-in cap. Changing the phone to 144/230 mode can improve speed over the default setting of 144K, as it removes the phone's built-in cap Arshad farooqabad mobile no/ 00923004802262 |
The Following 2 Users Say Thank You to arshad_ali77 For This Useful Post: |
Read User Code function via RJ45 for G810 | eddiman | UST Pro II | 0 | 08-19-2009 17:29 |
i need headset diagram for nokia = ptt function | hooi76 | Nokia Hardware & Hardware Repair | 0 | 01-10-2009 15:52 |
