Old 09-05-2008, 20:19   #1 (permalink)
Member: 239587
Thanks Meter: 6
Nokia E50 Display Solution Wanted
Hello Everyone
I have a Nokia E50 RM-170 with display issue. The problem is that its flashing (going white/blank every second and coming) continously, everything else is working perfectly
i have done everything i could but nothing helped, following are the things that i have done so far;
1. Factory setting with JAF
2. Flashed version 6.41
3. Flashed with latest 7.36 mcu + ppm
4. reflow emif ic's around display connector
5. checked display connector reballed emif ic's around display jack
6. checked LCD connector n flex cable
7. Applied heat to the PCB without removing metal shields
one thing i cant do is check LCD on other set or check other LCD on my E50 PCB even knowing 5300, 6233, 6234, 7370 etc are compatibles due to unavailability
im also very concerned whether this kind of problem is a known issue 'cause i have googled around so much but find nothing like this anywhere
if it is a known issue even in other nokia models than what is the cause (hardware or software) any clues are welcome,
Please suggest something..... im very upset n becoming hopeless
New LCD is very expensive, almost to the price of a used one
I cant understand yet whether its a hardware fault or a software error
Please Help
Thanks
Note: I have recorded a small mp4 video of the current condition 161k but unfortunately i cant upload it for some reason even after zipping it
The Following 4 Users Say Thank You to fsl13 For This Useful Post:
Old 09-05-2008, 21:30   #2 (permalink)
Member: 239587
Thanks Meter: 6
check it out
its the video
The Following User Says Thank You to fsl13 For This Useful Post:
Old 09-08-2008, 16:30   #3 (permalink)
Member: 219420
Thanks Meter: 74
PROBLAM SOLVE IN 5 MINT 1000000% WORKING USE THNX BOTTON TO THNX ME
ENJOY...............
The Following 5 Users Say Thank You to ikloveto For This Useful Post:
Old 10-05-2008, 07:38   #4 (permalink)
Member: 239587
Thanks Meter: 6
What are you talking about MR ikloveto????
There aint anything on the screen to thank about!!!
Please be precise on your help and check if there is a mistake done in posting something helpful
Thankyou
Old 10-08-2008, 11:40   #5 (permalink)
Member: 219420
Thanks Meter: 74
fsl check mini 6 lag crystal ic near display conector thn aftr remove matal sild & rehot rap ur problem vl solv
Old 01-30-2009, 11:47   #6 (permalink)
Member: 318022
Thanks Meter: 8
http://forum.gsmhosting.com/vbb/atta...3&d=1232216843
The Following 3 Users Say Thank You to dry_man For This Useful Post:
Old 06-03-2009, 03:54   #7 (permalink)
Member: 504047
Thanks Meter: 3
thanks, dry man It`s a good contribution
The Following User Says Thank You to jey_cy_pik For This Useful Post:
Nokia E50 joystick solution peter24533 Nokia Hardware & Hardware Repair 23 11-09-2011 14:34
Nokia E50 camera solution mahbubalfa Nokia Hardware & Hardware Repair 6 12-18-2010 16:52
Nokia E50 Mmc Solution mdc_indore Nokia Hardware & Hardware Repair 5 06-11-2010 08:26
Nokia E50 keypad solution tzlc Nokia Hardware & Hardware Repair 0 10-26-2009 12:23
Nokia e50 joys solution ::[email protected]:: Nokia Hardware & Hardware Repair 0 08-06-2009 13:07
Page generated in 0.27296 seconds with 8 queries
