09-18-2009, 11:28 | #1 (permalink) |
selective member algo bruteforce SL3 Join Date: Dec 2007 Location: IRELAND
Member: 665113 Status: Offline Sonork: 100.1583029 Thanks Meter: 1,165 | Nokia E51 Continiously Charging Repair Solution REQUIRED HERE!!! Everything seems to be ok with phone, has good signal all elements working, just one fault - Battery indicator keeps moving even if charger not pluged in. When you insert battery to powered off phone, light sensor LED lights-up and if try not to power on the phone battery barr will show up in right corner at the top of LCD as phone would be pluged in to charger. Phone has been carefuly cleaned out from liquid damage and dried out under high pressure hot airflow (below 180+C Degrees). It seems that phone is draining battery even quicker than usualy. Any hep? Thanks |
11-06-2009, 23:54 | #9 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | Quote:
Rashid Ahmed Nadeem | |
The Following 2 Users Say Thank You to r a nadeem For This Useful Post: |
Nokia 1650 Complete Hardware Repair Solution Nokia 1650 Sim ways Nokia 1650 buzzer | ..::akkas_sarkar::.. | Nokia Hardware & Hardware Repair | 4 | 05-10-2010 09:54 |
nokia e51 not charging | graceful2 | Nokia Hardware & Hardware Repair | 0 | 03-04-2010 14:29 |
nokia e51 not charge | iliralla | Nokia Hardware & Hardware Repair | 0 | 09-14-2009 21:02 |
need nokia e51 jumper on off solutions | tewariamit | Nokia Hardware & Hardware Repair | 0 | 09-03-2009 03:58 |
