04-14-2009, 20:07 | #1 (permalink) |
selective member algo bruteforce SL3 Join Date: Dec 2007 Location: IRELAND
Member: 665113 Status: Offline Sonork: 100.1583029 Thanks Meter: 1,165 | Nokia E51 Power-On Problem - C2510 Missing! NEED SOLUTION Power button has been checked and its ok. found one resistor missing (C2510) - please see E51 schematics attachment . Replacement resistor found but tracks are ripped of the PCB - anybody has alternate solution - jumper for this problem??? |
The Following 6 Users Say Thank You to Mr.Ultimate For This Useful Post: |
04-15-2009, 10:24 | #2 (permalink) |
Member: 665113 Status: Offline Sonork: 100.1583029 Thanks Meter: 1,165 | Have anybody had problem like this? Anyone can suggest me a solution...? I have been going trough other E51 PCB which is in good working order using multimeter looking for jumper connections but couldnt find anything... anybody could offer any solution would be very great...!! BR |
The Following User Says Thank You to Mr.Ultimate For This Useful Post: |
04-16-2009, 20:57 | #4 (permalink) |
No Life Poster Join Date: May 2008 Location: arth'*****
Member: 776884 Status: Offline Sonork: techno-gsm Thanks Meter: 152 | freind i make search 4 ur probleme but thats all i could get maybe help u http://fr.tinypic.com/view.php?pic=30w00aa&s=5 |
The Following 3 Users Say Thank You to techno-gsm For This Useful Post: |
08-16-2009, 16:09 | #6 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Dhaka,bangladesh Age: 41
Member: 193430 Status: Offline Sonork: [email protected] Thanks Meter: 123 | i need also that solution its urgent.............................plzzzzzzzzzzzzz zz |
The Following User Says Thank You to tutu1982 For This Useful Post: |
10-18-2009, 08:52 | #12 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 55
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Dear friends, handset behaves normally on cable and it gives fair response to charger means its on/off swich or its track from poweronx lead of the power ic (90%) here in this model there are two parts associated with the track they are marked in the picture attached( already posted in this forum) check connections to these part( REFER L3 and above scheam) if u cant cure the set u have to trace the track beneath power chip (extreme skilled work) good luck NEIL |
The Following 2 Users Say Thank You to neilthirumuttam For This Useful Post: |
10-18-2009, 12:17 | #15 (permalink) |
No Life Poster Join Date: Nov 2002 Location: slovakia Age: 46
Member: 17761 Status: Offline Thanks Meter: 91 | yes, its a jumper solution. you need a microscope and good skilled work. With sharp blade knife you must find small flattened by the lack of capacitors to the second layer circuit boards and conductive little legs combine the power-on button. This is not anything difficult. for 5 minutes you have done. I hope you know what I am talking about... |
nokia 6230 power on problem | nomi | Nokia Hardware & Hardware Repair | 0 | 11-27-2006 16:40 |
nokia 6230 power on problem | nomi | Nokia Hardware & Hardware Repair | 2 | 08-23-2006 19:00 |
nokia 6230 power on problem | screw8 | Nokia Hardware & Hardware Repair | 7 | 07-13-2006 09:30 |
Nokia 3230 Power on Problem | baba70 | n-Box | 3 | 06-17-2006 07:06 |
Nokia 1100 Power On Problem | clade | Nokia Hardware & Hardware Repair | 4 | 04-04-2006 22:07 |
