Nokia E63 blue screen problem help plz Nokia E63 blue screen 10sec then power off I try full flash But flash ok UI Settings failed Full flash with this version (rm437_510.21.010)But same problem Please any solution |
bro phone is sl3 or sl2? sl2 backup rpl then full erase and rewrite lastest version restore rpl,repair simlock also reapair sd and write 1&309 pm enogh sl3 backup rpl reset npc now imei go to 12345600123456 now phone enter local mode just back up simlock(120,308) full erase phone flash lastest version restore rpl and simlock pm repair sd write 1&309 pm enough befor try this methode you must write blank ppm some times phone is alive but i think no hope cuz after show blue display phone go to trun off :) |
check imei,rpl,and simlock data |
My problem solve i flash with blank ppm Thanks sir mak_1986 and thanks my all friends Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia ApeCoreSw: 510.21.010 Imei plain: 3553760467xxxx Product code: 0598720 Battery voltage: 3642 mV, current: 133 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355376046794595 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.860 s |
e63 blue light plz write blue light file e71 blank file 100% solution |
Thanks sir mak_1986............. Good job sir........... |
