08-04-2011, 14:46 | #2 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | same problem and no help in this forum for this problem some guys will tell to flash with ppm file but phone dnt even reading for flashing how you gonna flash this ppm file |
08-04-2011, 20:38 | #4 (permalink) | |
Freak Poster Join Date: Sep 2008 Location: Gujrat,INDIA
Member: 864966 Status: Offline Thanks Meter: 17 | Quote:
http://forum.gsmhosting.com/vbb/f609...-team-1319418/ | |
07-14-2012, 15:06 | #7 (permalink) |
Freak Poster Join Date: Jul 2008 Location: asdf
Member: 816948 Status: Offline Thanks Meter: 60 | flash with mx box flash with product code 100000000% ok MXKEY [FT SCR2000 0], SN: C080B5E9 Using device: USB ROM Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14102(15-06-2012) Processing MCU file: rm437_510.21.010_prd.c00 [BB5,XSR 1.5] size: 63.43 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 21B0011107970052155442416B40E2B45E1CD0B9 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5 CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 122.56 MB CMT FLASH,MuxOneNAND area [00040000-007FFFFF] CMT FLASH,MuxOneNAND area [00A00000-0759FFFF] CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: D9C25399 [RAP Certificate 137 v.1] sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS*CORE block sent CMT SOS+ROFS block sent Programming completed in 18 min 2.156 s Processing PPM file: rm437_510.21.010_prd.v42 [BB5,XSR 1.5] size: 25.95 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 33.56 MB CMT FLASH,MuxOneNAND area [05420000-0759FFFF] Formating partition ... Flash programming ... CMT SOS+ROFX block sent Programming completed in 7 min 36.532 s Processing CNT file: sofie_erase_y_drive.fpsx [BB5,XSR 1.5] size: 236 Bytes Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Erase size: 1.62 MB CMT FLASH,MuxOneNAND area [0F020000-0F1BFFFF] Flash programming ... Programming completed in 0.031 s Processing CNT file: RM437_ENO_008.07.45_100.71.952.a018.fpsx [BB5,XSR 1.5] size: 1.54 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 64 KB APE SOSENO Flash programming ... CMT SOS*ENO block sent Programming completed in 27.203 s Processing CNT file: rm437_510.21.010.43U [BB5,XSR 1.5] size: 22.57 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 64 KB Formating partition ... Flash programming ... Programming completed in 6 min 38.453 s Total time for flashing process(boot+erase+write) was 33 min 8.328 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2E66E91F Waiting for USB device removal ... Device connected: nmwcdc\Nokia E63 USB Phonet, PORT_ID: 33E85F1F Verifying communication to device OK. Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia ApeCoreSw: 510.21.010 Imei plain: 35200904827766-4 Product code: 0569937 Battery voltage: 3684 mV, current: 126 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352009048277664 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.172 s |
12-29-2013, 18:54 | #15 (permalink) |
Junior Member Join Date: Dec 2012 Location: ksa. al khobar
Member: 1857804 Status: Offline Sonork: [email protected] Thanks Meter: 2 | nokia 63 imei 123? how to solve pls help me |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
