Nokia E65 Screen Blink Hi I recently purchased a new LCD for my Nokia E65 through Ebay but when I install it, the image comes up but it blinks on & off. Is it a faulty LCD? how can I fix this? Thanks in advance - Sean |
chang formware ver then ok |
Thanks for that Adnan. It worked!!! If anyone wants the repair manual for Nokia E65 It can be found here http://rapidshare.com/files/52966733...l_1_2.pdf.html Also when the screen blinks, see if you can flash your phone firmware by checking here. http://www.nokia-asia.com/A4416041 Also if you are ever going to buy a replacement LCD from eBay make sure that its an original one. They all have a code printed on the back of the LCD. |
Hi Sean, I am run into this issue now. Purchased 3 lcd from couple of places, even the description say its original the back doesn't have any printed. How did you fixed your? by purchase one that have printed on the back or reflash fixed the problem? |
use the orignal dispaly i think u r paroblam lcd |
Where can I get original LCD? All the one sold on are original but having this problem. |
100%display problem...........change display |
But amazingly update sw fixed the issue. |
i am reacently having this problem.Is it chronic matter for e65?Can the firmware update solve this problem.I am really sick and tired about blinking screen? |
and i have one more question.Which one is cheaper?H-connector or screen? Regards |
before you change display ic change onnector |
Which one is right connector? Flex Cable Ribbon Flat LCD Screen Connector Nokia E65 - eBay (item 250648508653 end time Oct-07-10 23:51:53 PDT) or this one? NEW LCD Connector For NOKIA E65 10 pieces - eBay (item 320519467606 end time Sep-15-10 07:53:15 PDT) Thank you for all |
Why you not go with easier route first? Update sw work for me. |
