Nokia E7 Charging Problem i have one Nokia E7 which is not charging at all, i check all the tracks they are fine according to the charging ways picture of GSM Forum, is there any other way how to fix this phone, according to clint battery went flat and since it is not charging.. thanks |
1 Attachment(s) Quote:
Nokia E71 charging no response |
brother you said nokia E 7 and other member post new pic solve E 71 we need nokia E 7 and thanks for all |
HERE YOUR SOLUTION http://den.dikz.net/img/nokiae700u.jpg http://img847.imageshack.us/img847/6...p47kcharge.jpg |
i did check all the track they are fine..... and you know what Today i got another E7 with same problem , all the tracks fine but it does not charg, but the when i connect it to computer , pc does read the phone but does not charg,,, both of them |
hihi..I got few pcs E7 with the same faulty..I think this is set faulty coz I test with few original charger still same results..and the charger works well on other good E7..and I remove the battery and charge outside..its ok. BR |
change the USB connector |
i need e7 charger not supported,i dont have 47k btemp track.its broken. |
yes change the usb connecter but same not use connecter like n85 i have tested 2 set track is ok but no charging response use same connecter |
I have a E7. when i connect charger, it's volteg ok. but it's dont give any outpot. so plz give me a solution for this charging problem. plz. |
my mobile stop charging too my mobile stop charging with the charger but charging when connecting to my PC it works with this method for 3 days it goes empty then i charge it now it refuse to charge !!!!!!! is it a common problem with that phone ???? any help |
Nokia e7 100% solution 1 Attachment(s) Nokia e7 100% solution |
