Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 12-07-2011, 07:34   #1 (permalink)
Member: 372599
Nokia E7 Charging Problem
i have one Nokia E7 which is not charging at all, i check all the tracks they are fine according to the charging ways picture of GSM Forum, is there any other way how to fix this phone, according to clint battery went flat and since it is not charging.. thanks
Old 12-07-2011, 10:03   #2 (permalink)
lovepreet's Avatar
Member: 667436
Nokia E71 charging no response
Old 12-07-2011, 10:46   #3 (permalink)
Member: 1459601
brother you said nokia E 7
and other member post new pic solve E 71
we need
nokia E 7
and thanks for all
Old 12-07-2011, 12:40   #4 (permalink)
...::ARIF::...'s Avatar
Member: 1659825
Sonork: I..nOt..UsE
HERE YOUR SOLUTION
The Following User Says Thank You to ...::ARIF::... For This Useful Post:
Old 12-12-2011, 11:54   #5 (permalink)
Member: 372599
i did check all the track they are fine..... and you know what Today i got another E7 with same problem , all the tracks fine but it does not charg, but the when i connect it to computer , pc does read the phone but does not charg,,, both of them
Old 12-12-2011, 13:29   #6 (permalink)
lovepreet's Avatar
Member: 667436
did you check it by using orignal charger if both set showing same fault and track are ok then may be your charger is faulty so better you check it by a orignal charger and post results
Old 02-18-2012, 12:47   #7 (permalink)
Member: 1395476
Sonork: Men7896
hihi..I got few pcs E7 with the same faulty..I think this is set faulty coz I test with few original charger still same results..and the charger works well on other good E7..and I remove the battery and charge outside..its ok.
Old 02-25-2012, 21:56   #8 (permalink)
Member: 36010
change the USB connector
Old 02-26-2012, 05:40   #9 (permalink)
Member: 1724310
Sonork: 1111111111111111
bro chak................and try..........imegeshak
Old 03-08-2012, 06:13   #10 (permalink)
Member: 517072
i need e7 charger not supported,i dont have 47k btemp track.its broken.
The Following User Says Thank You to koireng For This Useful Post:
Old 07-14-2012, 07:07   #11 (permalink)
Crazy Poster
Member: 242711
Old 08-03-2012, 12:32   #12 (permalink)
Member: 1485341
yes change the usb connecter but same not use connecter like n85 i have tested 2 set track is ok but no charging response use same connecter
Old 01-21-2013, 09:38   #13 (permalink)
Member: 1868321
I have a E7. when i connect charger, it's volteg ok. but it's dont give any outpot. so plz give me a solution for this charging problem. plz.
Old 01-29-2013, 02:31   #14 (permalink)
Member: 669503
my mobile stop charging too
my mobile stop charging with the charger but charging when connecting to my PC
it works with this method for 3 days it goes empty then i charge it
now it refuse to charge !!!!!!!
is it a common problem with that phone ????
any help
Old 02-16-2013, 07:15   #15 (permalink)
imrankhan0143's Avatar
Member: 1796401
Sonork: 1623409
Nokia e7 100% solution
File Type: jpg Nokia E7-00 charging and usb ways Solution.jpg (237.2 KB, 485 views)
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.41141 seconds with 12 queries
