Old 05-13-2012, 10:25   #1 (permalink)
Member: 1696994
Thanks Meter: 19
Nokia E7 Charging / Usb pinout Emergency quick reply please
I have a Nokia E7, have replaced the charge / usb port, now it does not respond to the charger, I have checked the pin out from the brill diagram on here but mine is in reverse of what it says, ie pin 5 is ground on mine, not pin 1 as in the diagram....
When I plug charger in, it just reads as dead short, using bog standard usb charger with red light on, the light goes out when plugged in, using an lg cable, is the Nokia cable different..
Old 05-13-2012, 10:49   #2 (permalink)
Member: 1696994
Thanks Meter: 19
Should have said pin 1 is ground on my circuit board
Old 05-13-2012, 10:57   #3 (permalink)
Member: 1696994
Thanks Meter: 19
is the pinout diagram right?
Old 05-13-2012, 11:02   #4 (permalink)
Member: 1696994
Thanks Meter: 19
can anyone quickly help
Old 05-13-2012, 11:34   #5 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,122
this may help u . post result
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 05-13-2012, 11:39   #6 (permalink)
Member: 1696994
Thanks Meter: 19
I have looked at this, thanks, its just the pinout on my board is backwards to the pinout on here
Old 05-13-2012, 13:05   #7 (permalink)
Member: 1696994
Thanks Meter: 19
What two connections do I need for the charger to work?
Old 05-13-2012, 15:41   #8 (permalink)
Tabrez1's Avatar
Member: 1343156
Thanks Meter: 45
No Bro two connection not work fine,You need charger connecter five pin work...After the charger work good.
Old 05-13-2012, 18:07   #9 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 234
Old 05-13-2012, 19:11   #10 (permalink)
Member: 1696994
Thanks Meter: 19
Originally Posted by anujc143 View Post
Can I look stupid and ask, the diagram here only shows one connection? what about the other ones?
The Following User Says Thank You to G1mobile repair For This Useful Post:
Old 05-13-2012, 19:12   #11 (permalink)
Member: 1696994
Thanks Meter: 19
Also connection 1 is ground on my board whereas the pin out shows 5 as ground???
Old 05-14-2012, 10:50   #12 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,122
can u post here ur pcb image ? seems ur pcb is differ from schematics that I have .
Old 05-14-2012, 11:57   #13 (permalink)
Member: 1696994
Thanks Meter: 19
The pcb looks the same as in the usb pinout exactly but the conenctions are all reversed, as against the pinout published here
Old 05-27-2012, 21:17   #14 (permalink)
Member: 1696994
Thanks Meter: 19
I have used links to connect my usb port to the correct points but still no response from charger
Old 08-10-2012, 18:02   #15 (permalink)
Member: 1679541
Sonork: chris_one45
Please help, I have just disassembled my nokia e7 and found the usb charging port missing 2 contact pins, it looks like i have to de-solder to remove and replace the charging port , can the experts show me a guide as there is nothing on youtube to help on the subject.
Thanks in advance
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.39966 seconds with 9 queries
