Old 12-07-2010, 11:31   #1 (permalink)
Member: 269885
Thanks Meter: 50
nokia e75 insert sim problem
i got a nokia e75 wid offline mode wen i select any of profile to got my network it shows insert sim,den i off the fone and put another sim to checkd it, it acepted the sim gave signal but after 2 minut again leaved the sim and shown offline mode.i opend the fone to chked sim jacket value it shown perfect value.i searched on google for this error but nothing found any solution.
have any one any solution any idea for this error
thx in advance
The Following User Says Thank You to burraq For This Useful Post:
Old 12-08-2010, 09:49   #2 (permalink)
Member: 269885
Thanks Meter: 50
still waiting for a genuis reply can some body help me?
Old 02-11-2011, 08:26   #3 (permalink)
Member: 295762
Thanks Meter: 130
Check capasitor in schematic,other ways change avilma
Old 09-30-2011, 08:37   #4 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 283
[IMG]http://3.bp.********.com/_haRAPmO1Seg/TTWt-RkH-XI/AAAAAAAAA8o/9Z4WT8oF9zs/s400/Nokia+e75+insert+sim+card+solution.jpg[/IMG]
You may trace each of the SIM card pin connectors down to each corresponding capacitors. Check the SIM supply voltage (VSIM) for about about 2.9 volts on the corresponding capacitors and VSIM pin connector.
All the SIM data signal is feeds to and from the AVILMA IC, there is a possibility that the SIM error problem is caused by a faulty AVILMA chip, reworking or replacing it will only fix the problem.
A Problem with sim and offline mode on E75 like, The phone goes into an offline state and indicates "insert simcard". The screen goes white and flickers and the buttons gets unresponsive. Sometimes, but not always, then you will opted to restart the phone to an offline mode and manually go online.
This problem can be fix by firmware update.
Old 09-30-2011, 11:00   #5 (permalink)
Member: 581030
Thanks Meter: 13
make sure all screws are back on the phone and try again
Old 09-30-2011, 11:04   #6 (permalink)
senfour's Avatar
Member: 1624653
Thanks Meter: 390
http://forum.gsmhosting.com/vbb/f148...ction-1355477/
Page generated in 0.18782 seconds with 9 queries
