Old 09-12-2008, 10:22   #1 (permalink)
subhdra's Avatar
Member: 475086
Thanks Meter: 5
nokia falsing porblem 7610
nokia7610 falsing porblem hel what porblem
Getting MCU ID
MCU ID: 0x1081
FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
Setting local mode...
Failed! Aborting!
Failed! Aborting!
Failed! Aborting!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-67\RH51_52_67_68PE605220.C1
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-67\RH67PE605220.60
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-67\RH51_52_67_68PE605220.C1
Booting phone...
MCU ID: 0x1081
BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x10D8
Boot is ready...
Flash ID is 0xDDFE00EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
Loader size is 0x7F10; Loader chk: 4
Loader is ready...
MSID: 84404347C057BCFFB1102A5292
MSID decoded: 3E4EBAF70014A2F1A9000000
FAID: FFA6281AFBDCEADD0323ADED
Operation took 0 minutes 20 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 00FFFFFF...
Erasing area: 02000000 - 0287FFFF...
Erasing area: 02FC0000 - 02FEFFFF...
Operation took 2 minutes 57 seconds...
Writing...
Error cmd: 14!
Addr: 00000000
Old 09-12-2008, 10:26   #2 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
can you try by ufs-3.and post me what show in flash,,,,
maybe i will help u
Old 09-12-2008, 10:28   #3 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
i know u try by jaf,,,but better ufs-3 for me.i can tell what the problem,,,
now i see flash ic have some problem,,but u try ufs-3 after i talk
Old 09-12-2008, 11:18   #4 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
getting mcu id
mcu id: 0x1081
flash id0: Ddfe00ec <=> samsung (sec) -> type not in database addr0: 0x00000000 - 0x00ffffff, sectorsize0: 10
flash id1: Eefe00ec <=> samsung (sec) -> type not in database addr1: 0x02000000 - 0x02ffffff, sectorsize1: 10
flash id2: 225000ec <=> samsung (sec) -> k8s6415etb addr2: 0x04000000 - 0x04ffffff, sectorsize2: 10
flash id3: 00010000 <=> flash -> not used addr3: 0x06000000 - 0x06ffffff, sectorsize3: 0
first 16 bytes: Ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
checking ram for algo...
Algo is ready...
Checking faid calculation...
done!
Phone restarted...
Failed! Aborting!
Failed! Aborting!
Failed! Aborting!
Files set for flashing:
Mcu flash file: None
ppm flash file: None
cnt flash file: None
adsp flash file: None
ape variant file: None
ape user flash file: None
phone type:
Mcu flash file: C:\program files\nokia\phoenix\products\rh-67\rh51_52_67_68pe605220.c1
phone type:
ppm flash file: C:\program files\nokia\phoenix\products\rh-67\rh67pe605220.60
mcu: C:\program files\nokia\phoenix\products\rh-67\rh51_52_67_68pe605220.c1
booting phone...
Mcu id: 0x1081
boot file: C:\program files\odeon\jaf\flash\w3_2nd.fia
loader version: 04.46.01 -> revision: 0007
boot size is 0x10d8
boot is ready...
Flash id0: Ddfe00ec <=> samsung (sec) -> type not in database addr0: 0x00000000 - 0x00ffffff, sectorsize0: 10
flash id is 0xddfe00ec
flash loader is c:\program files\odeon\jaf\flash\w3_amd.fia
loader size is 0x7f10; loader chk: 4
loader is ready...
msid: 84404347c057bcffb1102a5292
msid decoded: 3e4ebaf70014a2f1a9000000
faid: Ffa6281afbdceadd0323aded
operation took 0 minutes 20 seconds...
Erasing...
erasing area: 00000000 - 0000ffff...
Erasing area: 00010000 - 00ffffff...
Erasing area: 02000000 - 0287ffff...
Erasing area: 02fc0000 - 02feffff...
Writing...
Error cmd: 14!
Addr: 00000000
yes i agree......
1st erase flash.
2nd write flash with good pm and unlock.
Then post result......................................
Old 09-12-2008, 11:21   #5 (permalink)
westgold's Avatar
Member: 734668
Thanks Meter: 83
jaf can solve that problem just follow their suggestion full erase, full flash write good pm
Old 09-12-2008, 13:56   #6 (permalink)
Member: 696372
Thanks Meter: 11
i try ful erase then flash but not get success
Old 09-12-2008, 14:12   #7 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
try again,,if not sucess some rehot upp then try,,,,,(if possiball show me why can't erase,,,,)i mean what show in ur desktop
Old 09-12-2008, 14:19   #8 (permalink)
shivashakthi's Avatar
Member: 594753
Sonork: 100.1605626
Thanks Meter: 822
try reboo flash ic or light hit
Old 09-12-2008, 14:35   #9 (permalink)
dvsbbdd's Avatar
Member: 703284
Sonork: 0
Thanks Meter: 66
now i see flash ic have some problem,,but u try ufs-3 after i talkme hit flash ic or light hit
Old 09-12-2008, 15:25   #10 (permalink)
mobile house dinajpur's Avatar
Member: 724680
Sonork: 100.1595118,1603297
Thanks Meter: 928
uem problem may be.........
Old 09-14-2008, 16:11   #11 (permalink)
subhdra's Avatar
Member: 475086
Thanks Meter: 5
1st Boot: Ok, WD2, UPP: 1081 [Rh-67] [2.0.7.2]
2nd Boot: w3_2nd.fia, Ver: 4.70.1
Fl0: 0x00000000-0x01FFFFFF,00ECDDFE,Sam K8S5615ETA
Fl1: 0x02000000-0x03FFFFFF,00ECEEFE,Sam K8S5615ETB
Fl2: 0x04000000-0x047FFFFF,00EC2250,Sam K8S6415ETB
Algorithm: w3_amd_b.fia, Ver: 4.70.1
Algorithm Ok, MSID: 84404347C057BCFFB1102A5292
Decoded MSID: 3E4EBAF7-0014A2F1-A9000000
Encoded FAID: FFA6281A-FBDCEADD-0323ADED
IMAGE: RH51_52_67_68PE605220.C1
Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00
Area2: 0x00010000-0x00FFFFFF Erased, Time: 02:06
Area3: 0x02000000-0x0287FFFF Erased, Time: 01:06
Area4: 0x02FC0000-0x02FEFFFF Erased, Time: 00:01
Write Error: hDat 14, at: 0x00002000:08
Process Failed, Repowering Mobile
Old 09-14-2008, 17:47   #12 (permalink)
Registered User
Member: 828691
Thanks Meter: 33
rehot flash ic no 0 or ram ic n slowly rehot(warning)
Old 09-21-2008, 10:47   #13 (permalink)
Member: 199996
Thanks Meter: 41
Water damaged 7610 flashing completed: But power not on:
any brother give me perfect solution
Old 09-21-2008, 10:57   #14 (permalink)
Crazy Poster
Member: 722092
Thanks Meter: 16
clean and rehot board.after try software.then post result..........
7610 falsing porblem subhdra Nokia Hardware & Hardware Repair 8 07-15-2008 07:27
1100 falsing porblem subhdra Nokia Hardware & Hardware Repair 0 05-05-2008 09:27
3230 nokia falsing porblem subhdra Nokia Hardware & Hardware Repair 3 04-22-2008 07:34
Websites for Free Nokia 6600 & 7610 Applications rsrusli Nokia Multimedia 3 07-23-2004 07:57
Page generated in 0.24341 seconds with 10 queries
