Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 07-22-2007, 05:03   #1 (permalink)
mobilagy's Avatar
Member: 217479
Thumbs up Nokia Flash Chips number on board
Here is pictures showing flash chips number on board for some Nokia models, hope it helps, B.R ...
Old 07-22-2007, 19:16   #2 (permalink)
Registered User
Member: 483748
u mentioned wrong ad******* of n7610 u mentioned upeer is f12 and lower is f10 and f11.but upper is f10 and 11 and the lower is f12.if u r correct then replay correctly .and say me one thing if we interchange what ist shows?
Old 07-23-2007, 03:13   #3 (permalink)
mobilagy's Avatar
Member: 217479
About 7610 there's two boards design; one as i mentioned & the other as you did, B.R ...
By the way, you have to know that flash areas number is Fl0, Fl1, Fl2, Fl3 ...etc , not F10, F11, F12, F13 ; the second character is the letter "L" not the digit "1" .
Old 07-23-2007, 03:18   #4 (permalink)
Member: 108346
Thanks for your share..............
Old 07-24-2007, 06:38   #5 (permalink)
Registered User
Member: 483748
i mean it second character is "L". THEN HOW CAN WE IDENTIFY THE SECOND BOARD U HAVE ANY IDEA.AND ONE IMPORTANT QUEST IF WE INTERCHANGE FLASH IC'S THEN WHAT IT SHOWS.mean to say if we treat ist board as to second board then any error occure or not.
Old 07-24-2007, 06:58   #6 (permalink)
mobilagy's Avatar
Member: 217479
First of all you must be more honest; you was know it as digit "1" cause you have write it three times like that & i have corrected that for you.
Second matter; of course we have to determine each board design cause it will not work if the two flash chips interchanged.
Third; you can identify them simply by chip size; big one is Fl0 & Fl1 , small one is Fl2 , & that was the easiest way otherwise by chips manufacturer number like K8S6415ETA & K875615ETA or equals.
Hope it was helpful ...
Old 07-25-2007, 09:43   #7 (permalink)
Registered User
Member: 483748
i know it is fl0,fl1 but when we talk that time we use word f10,f11 etc.in our language. second it is not necessary both ic's are in different size.sometime may be in same size .what do u think about it. y/n
i like ur way of talk.
Old 07-25-2007, 14:45   #8 (permalink)
mobilagy's Avatar
Member: 217479
Thnx mate, you are welcome.
No man, it can't be the same size ever, the one you see that they are the same size they are not; only just millimeter or less is different between them.
Old 07-25-2007, 20:19   #9 (permalink)
Registered User
Member: 483748
thanx for all of ur wonderful sharing of knowledge.
Old 07-26-2007, 13:11   #10 (permalink)
tshcom's Avatar
Member: 224312
thanks you......... that's good...............
Old 08-24-2007, 08:32   #11 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
very good
thanx Mr.
GsmJoman
Tc
Number Keypad Board with Ribbon for SAM U900 - Original IPMART ipmart WebShop 0 11-12-2009 09:50
Number Keypad Board with Ribbon for SAM G600 - Original IPMART ipmart WebShop 0 11-12-2009 09:50
nokia 6085 display problem on board dashraj Nokia Hardware & Hardware-Repair Area 2 07-22-2008 10:17
6610,7250,3100,6600,3650/60 flash chip numbers cgsm Nokia Hardware & Hardware-Repair Area 21 05-04-2007 12:00
remove a chip so balls stay on board? hulala.[uk] Nokia Hardware & Hardware-Repair Area 14 10-11-2003 18:06
Page generated in 0.63001 seconds with 12 queries
