12-20-2008, 17:32 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Afghanistan
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | Nokia Hardware Problem?? Just Knock Here For Fast Reply Nokia Hardware Problem?? Just Knock Here For Fast Reply. The New And Old Nokia Hardwear Problem. You Will Get Reply In 24 Or 48 Hour...Insh*****. Just Nokia Here.....? Thanks ! Regards Khisrow Safi Note:If You Have Or (Got) Problem Then Plz Tell As With Full Details.That Is Is The Problem...? Last edited by khisrow; 12-20-2008 at 17:42. |
The Following 11 Users Say Thank You to khisrow For This Useful Post: |
12-20-2008, 18:51 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: MUMBAI
Member: 583454 Status: Offline Thanks Meter: 80 | 3100 no network found sometimes get solved by fitting but get dropped after few hours . . . Same problem is seen in 3-4 different mobiles weither 3100 or 3120 . . . What to do for permanent soln ? |
12-20-2008, 20:57 | #4 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | knock...! knock...! N95 sl_wakeup_test: fail phone cant start up, somtimes show nokia i have 20 pcb. of this phones with same foult, some phones can but sometimes, some phones boot if i press resett buttons ( 3 # green and power on keys)... |
The Following User Says Thank You to oOXTCOo For This Useful Post: |
12-21-2008, 08:31 | #5 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 45
Member: 351924 Status: Offline Thanks Meter: 12,467 | Quote: try to chnage that good | |
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
12-21-2008, 16:21 | #6 (permalink) | |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | Quote:
First Of All Do It Form Software . How ? Full Flash It Then Write Good Pm On It. If Not Done Your Problem Then Try This It Will Be Ok. | |
12-21-2008, 16:33 | #8 (permalink) | |
Dear Brother I Will Try Mostly And i Will Post You The Solution Insh*****. Thanks Regards Khisrow Safi | |
12-21-2008, 16:47 | #9 (permalink) | |
Wait I Will Post What You Want Brother But Net Problem Hope That Don"t Mind........Thanks Regards Khisrow Safi | |
12-21-2008, 18:15 | #13 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 577307 Status: Offline Thanks Meter: 58 | Dear khisrow, I have keypad problem in 2600c. Ihad changed keypad ic but these keys are not working menu, softleft,left, softright,right,up,and down.Waht is the solution for this problem it is urgent. |
12-21-2008, 18:19 | #14 (permalink) | |
Try This Solution If Not Work Then Tell Me..? Thanks Brother Regards Khisrow Safi [email protected] | |
12-21-2008, 18:28 | #15 (permalink) | |
Dear Brother Try With Oignal Ic Now A Days The Ic Is Not So Perfect For Buying. Every Time When I Want Change The Ic Then I Peck Up The Ic Form Another Sits Like That Or Like The Same Ic Form Another Mobile . Note:So Try It With A Oignal Ic . If Your Problem Is Not Done Then Again Conferm Me Up To That Time I Will Try My Best To Help Your Brother.. Thanks Regards Khisrow Safi | |
The Following User Says Thank You to khisrow For This Useful Post: |
All Nokia Hardware ne Upgrade Solution Here in 24 Hours | CityGSM | Nokia Hardware & Hardware Repair | 136 | 06-15-2012 13:31 |
*****WIcked Work Jtag For Fast Reply***** | Amir-SkillZ | SAGEM JTAG UNLOCKER | 4 | 01-16-2006 09:45 |
All Nokia 3310 problems please put here for quick solution | gsmindia | Nokia Hardware & Hardware Repair | 2 | 07-30-2005 00:20 |
Anyone that can help me here?need fast reply | projectzen | Nokia Multimedia | 6 | 03-22-2005 02:16 |
