Old 09-10-2015, 07:15   #1456 (permalink)
Member: 294742
Thanks Meter: 5
Nokia Lumia 520 on off full damage any solution
Old 09-12-2015, 09:39   #1457 (permalink)
Member: 1048937
Thanks Meter: 32
nokia lumia 520
ineed battery connector resistor continuity value
battery connector + to -
battery connector bsi to -
Old 09-12-2015, 09:52   #1458 (permalink)
Member: 1048937
Thanks Meter: 32
nokia lumia 520
i need battery connector resistor continuity value
battery connector +(positive) to -(negative)
battery connector Bsi to -(negative)
Old 09-14-2015, 09:08   #1459 (permalink)
Member: 2431049
Sonork: 100.1680262:hunnyck
Thanks Meter: 966
Nokia c3 00 keypad ic change & jumper ok but menu & all switch not working how this solution plz help me. ..
Old 09-16-2015, 18:31   #1460 (permalink)
samirov-gsm's Avatar
Member: 759168
Thanks Meter: 12,866
Originally Posted by qarni View Post
sir g nokia 225 wiht lcd problm lcd jack continiuty is ok but lcd chang lcd jck chang problam sam
http://www.u2ugsm.com/blog/nokia-225...-problem-ways/
The Following User Says Thank You to samirov-gsm For This Useful Post:
Old 10-03-2015, 09:55   #1461 (permalink)
Member: 2431049
Thanks Meter: 966
nokia 201 keypad ic ok but all key not working
solution plz help me .............
Old 10-07-2015, 12:03   #1462 (permalink)
Member: 1453110
nokia 202 blinking wight display 100% ok done by me
Old 10-29-2015, 12:19   #1463 (permalink)
Member: 1565811
Sonork: 786
Thanks Meter: 8
pls help me......nokia 220 water damage ,after key pad not working......4.5.6 buttions not working pls help...
Old 10-30-2015, 09:40   #1464 (permalink)
Member: 1705260
Sonork: masum
Nokia 1202 Hardware Solutions
thank you
Old 01-01-2016, 16:32   #1465 (permalink)
Member: 759168
http://haiderymobile.yolasite.com/nokia-1202.php
The Following 2 Users Say Thank You to samirov-gsm For This Useful Post:
Old 01-03-2016, 08:53   #1466 (permalink)
Member: 2431049
Thanks Meter: 966
nokia lumia 610 LCD LITE solution...............plz
Old 04-27-2016, 11:38   #1467 (permalink)
Member: 2525512
Sonork: matrixent77
Nokia 1100 converting
Old 05-05-2016, 07:49   #1468 (permalink)
Member: 2568771
Cool Nokia 1200 pls..
Nokia 1200 solution pls..
Old 05-06-2016, 14:26   #1469 (permalink)
Member: 2545232
pls tell me tool for flashing nokia mobiles
Old 09-06-2016, 10:39   #1470 (permalink)
SLSUTHAR's Avatar
Member: 2482480
Thanks Meter: 112
nokia 205 restart when calling need solution
Page generated in 0.21934 seconds with 10 queries
