05-09-2011, 05:42 | #1 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1543303 Status: Offline Thanks Meter: 1 | Nokia 5310 shutdown - battery is full Please help me fix this Nokia 5310 Client says that phone shuts down when he calls or receives a call. When I try the phone I see that: - Battery is good (multimeter shows 3.7V) - Sometimes it reads my SIM sometimes not - Battery empties very fast - it goes to 3.5 after first 0 second call When I removed the earpiece: - Phone can make calls - The SIM problem still exists Please help! |
The Following User Says Thank You to nabil_kadimi For This Useful Post: |
05-09-2011, 07:36 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Cel_Phon - M.B.Din
Member: 328187 Status: Offline Thanks Meter: 1,687 | remove earpiece and check again.....if work then replace speaker or check speaker terminals position if battery empty very fast then remove BT module and check for sim u must check sim tray .....i think that is lose replace inner body and check |
The Following 2 Users Say Thank You to imran zafar For This Useful Post: |
05-09-2011, 08:49 | #6 (permalink) | |
Member: 328187 Status: Offline Thanks Meter: 1,687 | Quote:
check imei......how much consumption of set? it is same if u make call with supply ? | |
05-09-2011, 09:15 | #7 (permalink) | |
Member: 1543303 Status: Offline Thanks Meter: 1 | Quote:
I can make calls when cable is on, but the phone will discharge and stop if I remove the cord. Please what is "consumption of set" EMEI is : 358002032511143 | |
05-09-2011, 09:31 | #8 (permalink) |
Member: 328187 Status: Offline Thanks Meter: 1,687 | witch kind of external power u r using for battery substitute? 1st u confirm that ur battery is ok.......clean battery terminals of board 2nd if there is same condition with other battery or other power source ...then.... check earpiece and earpiece ways.......reflash ur set ....... consumption mean ....a load of current witch is consuming in circuit .....u can measure this load with a normal set |
The Following User Says Thank You to imran zafar For This Useful Post: |
05-09-2011, 19:32 | #9 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1411420 Status: Offline Sonork: 1987 Thanks Meter: 1 | Hi Nabil please note the difference between fate battery and original one. simply replace the battery with a new one.the problem is from the battery. if you do this the problem will be solve. |
The Following User Says Thank You to nnaka cletus For This Useful Post: |
