Old 05-09-2012, 15:16   #1 (permalink)
Member: 1263622
Thanks Meter: 149
Arrow """nokia x2-05"""
Need help........nokia x2-05 RM-772 flash done with...mxbox,atf, but problem not solved....set problem..... power on after...hang. & restart ...
how to solved it ??????????any idea give me any sir ?????????????
Old 05-09-2012, 18:54   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
post here selftest result .
Old 05-09-2012, 20:06   #3 (permalink)
ms phone's Avatar
Member: 1119242
Sonork: 100.1638541
Thanks Meter: 121
change power ways [IMG]http://2.bp.********.com/-wLx6K-aTfYE/T0NkU_Qs7zI/AAAAAAAAAwg/yY94-jCfaig/s1600/Power-Switch-ways.jpg[/IMG]
The Following User Says Thank You to ms phone For This Useful Post:
Old 05-10-2012, 12:06   #4 (permalink)
Member: 1263622
Thanks Meter: 149
Arrow
i will try..this solution but problem not solved.....other solution give me plz ??????
Old 05-11-2012, 06:04   #5 (permalink)
gsm-iran's Avatar
Member: 188646
Thanks Meter: 76
hi
try to remove camra ................
The Following User Says Thank You to gsm-iran For This Useful Post:
Old 09-13-2012, 05:51   #6 (permalink)
DarkManDZ's Avatar
Member: 431529
Thanks Meter: 18
hi masters , need audio ways please
Old 09-13-2012, 06:57   #7 (permalink)
biniesh_08's Avatar
Member: 843418
Thanks Meter: 740
br change new display try it.........
Old 12-10-2013, 12:04   #8 (permalink)
Fragga's Avatar
Member: 1507693
Thanks Meter: 131
same problem here, nokia x2-05 was working fine only the browser was not opewning so after flashing the phone restart and hang, i removed camera buit not work
card found: S/N 87A0:0122
registered to: fragga
Connect phone on selected interface...
IDM initializing, wait...
Checking access to Products folder...
Folder for RM-772 exist
Prepare done, collect info
[Query] : rm772__08.60.mcusw , 25.72 MB
[Query] : rm772__08.60.ppm_c , 4.99 MB
[Query] : RM772_059H0P2_08.60_032.vpl , 3.36 KB
[Query] : rm772__08.60.image_c_059H0P2 , 13.59 MB
Total size to download : 44.30 MB
Downloading now, please, wait...
[Download] : rm772__08.60.mcusw
Core : v1.76 , BB5XG FlashEngine : v7.0
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm772__08.60a.mcusw
PPM : rm772__08.60a.ppm_d
CNT : rm772__08.60a_001.image_d_tele2_hr_9n8g1
Flashing phone now...
Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.46_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI : 352420053643148
PCcode : 059M5J1
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\352420053643148_XG 213_CRT.rpl
===Flashing [MCU]===
File : rm772__08.60a.mcusw
Image : rm772__08.60a.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x018C0000
Erasing, wait ...
Erase done, time : 00:02:16
Write , Start : 0x40280000 , Len : 0x01840000
Flashing , wait ...
Region flash done, time : 00:00:36
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0x053E
===Flashing [PPM]===
File : rm772__08.60a.ppm_d
Image : package_d.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41B40000 , Len : 0x00700000
Erasing, wait ...
Erase done, time : 00:00:31
Write , Start : 0x41B40000 , Len : 0x0055527C
Flashing , wait ...
Region flash done, time : 00:00:07
CRC check passed , 0xE05B
===Flashing [CNT]===
File : rm772__08.60a_001.image_d_tele2_hr_9n8g1
Image : /build/rm772_sw_settings/temp/059N8G1/CONTENT_CONFIG/package_
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42240000 , Len : 0x01BE0000
Erasing, wait ...
Erase done, time : 00:04:17
Write , Start : 0x42240000 , Len : 0x00D20000
Flashing , wait ...
Region flash done, time : 00:00:24
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:08
No write data, skip
CRC check passed , 0x5DA2
Flashing done!
Total flash time : 00:08:31
Reboot phone now...
Reading Phone Info....
Connected phone - X2-05
Software Info: V 08.60a 27-12-11 RM-772 (c) Nokia
IMEI: 352420053643148
PPM version : V 08.60a 27-12-11 RM-772 (c) Nokia D
Product code: 059L9M1
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 42 certs
Data exist, skip certificate repair...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Elapsed: 00:09:35
[Download] : rm772__08.60.ppm_c
Phone found!
Series 40 Device detected!
read info... - Ok
Old 02-21-2014, 18:57   #9 (permalink)
Member: 1278793
Thanks Meter: 68
same with me here flash ok when power on it hang and restart
Old 03-03-2014, 06:30   #10 (permalink)
Member: 1278793
Thanks Meter: 68
problem solve by changing lcd
sagem my-x2 unlocking codes...plz! thecremeegg Phone Unlocking Codes & Maps 1 10-09-2003 20:38
Sagem My-x2,x6,g5 nyonyo Wanted Products 1 09-18-2003 15:02
Solution for MY X2 VINCECHRIS Phone Unlocking Codes & Maps 0 09-16-2003 06:57
Solution for MY X2 ???? VINCECHRIS ARM9 BASED M62 / M62+ 2 09-15-2003 18:04
my-x2 unlock code ? equinoks Phone Unlocking Codes & Maps 0 09-08-2003 13:09
Page generated in 0.21777 seconds with 9 queries
