Old 02-28-2007, 17:46   #1 (permalink)
Member: 403881
Thanks Meter: 80
2600 Problem
2600 while connect to software LOCAL MODE Appears in LCD but not Power ON by Battery. Some one have solution?
Old 02-28-2007, 17:52   #2 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
change the uem ic your problem is solve
b.r.
yuvi.
Old 03-01-2007, 05:39   #3 (permalink)
Member: 403881
Thanks Meter: 80
Yuvi Sir have U changed UEM in 2600 earlier? If yes, than please tell me the trick bcoz it is glued.
Old 03-01-2007, 10:55   #4 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
no problem is in pm full flash the phone with good pm
I repaired 3 sets like this
post result
Old 03-01-2007, 13:12   #5 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
yes glued ic can be replaced ....use search 4 more info...........as far as ur 2600 ..........full flashing ur set with good pm after erase would be better idea than replacing uem ic.........
2600 Problem With China Display cgsm Nokia Hardware & Hardware Repair 3 08-07-2008 15:27
Nokia 2600 problem with PM gsm99 Nokia Digital Core Technology 4 ( DCT-4 ) 3 04-06-2006 11:42
Nokia 2600 problem :D Wizo Twisterflasher 5 02-06-2006 01:03
can't solve 2600 problems.... pritom Nokia Digital Core Technology 4 ( DCT-4 ) 1 08-24-2005 16:31
2600 problem after flashing REKIN_R.C. Griffin 4 04-22-2005 07:20
Page generated in 0.14857 seconds with 9 queries
