08-27-2004, 16:59 | #4 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Romania Age: 41
Member: 17740 Status: Offline Thanks Meter: 1 | it's not about rionger or ronger ic it's about 4 little pieces wich i don't know their ways because client drop it and now i can't make it work i need ways of ringer!!! please |
09-03-2004, 14:01 | #6 (permalink) |
Major Poster Join Date: Feb 2004 Age: 51
Member: 51849 Status: Offline Thanks Meter: 2 | I have 6100 with ringer / buzzer problems too. 1.Water damaged. Try to listen carefully as close as the buzzer when ring is played. If a little sound is heard, it must be amplifier buzzer problem. 2.If Not heard even little try to check UEM ( rehot carefully and or do reballing ), cause UEM responsible include power distribution and audio . Got succesfull on case 2, but on case 1 I still need scematic diagram for 6100 ringer circuit, cause I don't have 6100 schema. Please help! But |
09-03-2004, 19:52 | #7 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | @All whats going on at here, first check ringer circuit pads in diod function. put your RED WIRE ON GROUND OR BLACK ON CONNECTION, If its give somethign reading then U U U MUST MUST MUST change your finger ICs . if no reading at there , then must conform ringer trcks. THATS ALL . always same in all gsm phones. or forget about uem . uem is not responsible for this fault. this is 1000000000000 % conform solution on 6100,3100 ,3530. so dont vest your time in uem . @kki |
06-05-2008, 09:07 | #8 (permalink) |
Registered User Join Date: Apr 2008
Member: 741068 Status: Offline Sonork: asif Thanks Meter: 0 | Solution required of low sound of Nokia 3100 buzzer it is immediately please note my personal [email protected]hanks all waiting for best solution |
06-05-2008, 09:08 | #9 (permalink) |
Member: 741068 Status: Offline Sonork: asif Thanks Meter: 0 | correct address is [email protected] |
06-05-2008, 16:35 | #15 (permalink) |
Freak Poster Join Date: May 2008 Location: Uganda
Member: 774126 Status: Offline Sonork: 100.1645006 Thanks Meter: 42 | there seems to be a problem with uploading, but search the forum im sure you'll find one. |
The Following User Says Thank You to cavi For This Useful Post: |
good solution of 3100 buzzer problem | brahim | Nokia Hardware & Hardware Repair | 7 | 02-13-2009 16:25 |
S500i NO BUZZER (NEED BUZZER WAYS) | newstudent | Sony Ericsson Hardware Repair | 9 | 09-02-2008 09:09 |
3100 buzzer problem | gpong | Nokia Hardware & Hardware Repair | 15 | 06-24-2008 17:01 |
nokia 3100 not buzzer work///////// | abdone | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 11-02-2006 02:13 |
buzzer problem of 3100 | habibkhalil | Nokia Hardware & Hardware Repair | 1 | 12-28-2005 21:03 |
