07-24-2009, 14:19 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 254086 Status: Offline Thanks Meter: 24 | nokia N70 its giving this errer when i m flashing the phone Powering the phone... Reading... MCU SW version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. HW version: 6061 PCI version: RFIC version: 150a160f DSP version: rolf_05wk07v29p1 Retu version: 32 Tahvo version: 52 Production serial number: SVJ912805 Product code: 0541860 Module code: Basic production code: 0542519 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 353269017399209 IMEI spare to net: 3A 35 62 09 71 93 29 00 IMEI SV to net: 33 35 62 09 71 93 29 10 F2 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2343300000000000 Provider: Orange;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Block 3: Lock 1: OPEN Block 4: Lock 1: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0541860 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\ Scanning for ini files... INI file 0541860.ini is missing. Continue searching for second ini type... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-84\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: ? Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\ Scanning for ini files... INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V01 CNT Flash file: NONE APE Variant file: ? Backing up CRT data... Setting FLASH MODE Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Reading CMT NPC certificate... Reading CMT VARIANT certificate... Reading CMT CCC certificate... CCC not available... Reading CMT HWC certificate... HWC not available... Saved to C:\Program Files\ODEON\JAF\ProgData\35326901739920_CRT_backup _610247.rpl Backup CRT OK! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\353269017399209_CRT_backu p_611247.pm Done! Backup LCK OK! Manual mode selected, version can't be checked! Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006000C192101002200 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 0680010CE26D515118D7A2D64A63FD9178389A1B HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Operation took 0 minutes 5 seconds... Sending CNF Data... APE blocks present in flash file but no APE mcu detected in phone. Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V01 CNT Flash file: NONE APE Variant file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V01 CNT Flash file: NONE APE Variant file: NONE FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0 PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V01 CNT Flash file: NONE APE Variant file: NONE Backing up CRT data... Setting FLASH MODE Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Reading CMT NPC certificate... Reading CMT VARIANT certificate... Reading CMT CCC certificate... CCC not available... Reading CMT HWC certificate... HWC not available... Saved to C:\Program Files\ODEON\JAF\ProgData\35326901739920_CRT_backup _613247.rpl Backup CRT OK! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\353269017399209_CRT_backu p_614247.pm Done! Backup LCK OK! Preparing for downgrade... Phone ready for downgrade! Manual mode selected, version can't be checked! Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006000C192101002200 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 0680010CE26D515118D7A2D64A63FD9178389A1B HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Operation took 0 minutes 4 seconds... Sending CNF Data... APE blocks present in flash file but no APE mcu detected in phone. Aborting! sir what could be the problem any solution sir Thank u |
nokia 6500c its giving errer in flash | shakil143 | Nokia Hardware & Hardware Repair | 6 | 11-10-2010 06:22 |
When i flash nokia 6680,its show this. | omary | Nokia Hardware & Hardware Repair | 3 | 01-23-2010 11:26 |
nokia 1200 its giving this errer when Flashing | shakil143 | Nokia Hardware & Hardware Repair | 1 | 11-30-2009 12:45 |
how do i sholwe this problem when i m Downloding sons in ipod its giving this errer | patelfaizu | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 09-18-2009 08:04 |
nokia 1209 its giving this errer flashing time | patelfaizu | Nokia Hardware & Hardware Repair | 1 | 07-28-2009 08:15 |
