Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 02-14-2007, 07:38   #1 (permalink)
Member: 451006
Nokia N70 Sending Sms with out my will and order
hello guys, how are you? I am fine i have nokia n70 and recently i recognized that it sends SMS message to one particular number without my will and order. it also delets all the call registered in call log and it lists the number to which the sms sent
so what is the problem and how can i improve or solve the proble. it is consuming mu mobile batttery
thanks
Old 02-14-2007, 07:52   #2 (permalink)
Member: 432364
Format your handset by this way :-
press answer key ( green key ) + * + 3 + Power switch and wait untill the phone s how Nokia on the LCd and blinks giving it again because phone will not show Formatting word on the LCD as in 6600 and 7610 and 6670
And you can format by *#7370# then it will ask security code enter 12345 then phone will restart and problem will solve.
B.r.
Sunil.
Old 02-14-2007, 07:57   #3 (permalink)
Member: 299664
one thing more, after format, try instal anti virus.
Old 02-14-2007, 17:52   #4 (permalink)
Member: 101007
infected by virus bro
scan ur mmc wit anti virus format phone...
or use fexplorer to search out the virus file and delete it but make sure u kno the file name else jus format the phone
regards
Old 02-14-2007, 19:12   #5 (permalink)
Irfangk786's Avatar
Member: 146630
yes it's infected by virus.And follow instruction of psunil
Old 02-14-2007, 21:15   #6 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
backup ur phone book n format it manually.....
Old 02-15-2007, 03:33   #7 (permalink)
watari31's Avatar
Member: 141262
you are infected by a comwarrior virus!!!
solution is you can just format your phone or install a anti-comwarrior virus!! all application would be safe no need to format!!
Old 02-15-2007, 03:43   #8 (permalink)
Lhick's Avatar
Member: 333359
No need to Format, Install Anti Virus/ Browse Delete Virus.
Old 02-15-2007, 03:45   #9 (permalink)
yobb's Avatar
Member: 337450
its a virus sir, installl new anti virus....
Old 02-17-2007, 10:33   #10 (permalink)
Member: 451006
Thank you for your immediate response. I tried to scann using different anti viruses and anti commonworrier but the could not clean my phone. Actually |I could not format my mobile due to lack of knowledge. Thank you for ur suggestion.
May i ask you some question?
when i format my mobile what will be all default softwares installed
will i lose all my contac list?
will i lose any info stored in C:\
thank you
Old 02-17-2007, 11:13   #11 (permalink)
watari31's Avatar
Member: 141262
anti comwarrior for you mate!!
try this one mate put on the memory card and install. after install this automatic detect virus!!!
Old 02-17-2007, 11:18   #12 (permalink)
watari31's Avatar
Member: 141262
thank you
IF THIS ANTI COMWARRIOR CAN'T FIXED YOUR PHONE MUCH BETTER FORMAT YOUR PHONE USING *#7370# IT WILL ASK U RESTORED TO ORIG SETTING ETC. PRESS OK THEN ASK FOR LOCKED CODE STANDARD IS 12345 IF U CAHNGED IT PRESS THE LOCKED CODE U KNOW!!!
ALL DATA WILL BE LOST. ALL WOULD BE BACK TO ORIGINAL SETUP SEEMS LIKE WHEN U FIRST BY THE PHONE. BUT U ALSO HAVE TO FORMAT YOUR MEMORY CARD USING YOUR COMPUTER.. COZ MEMORY CARD ALSO INFECTED BY THE VIRUS.
REGARDS TRY IT MATE!!!
USING THIS PROCEDURE U NEED TO REMOVED YOUR INFECTED MEMORY CARD FORMAT IT BEFORE YOU PUT INSIDE YOUR PHONE!!!
sending sms to erase my simemu card ? eurka Sim Cloning and Scaning 1 10-27-2007 00:01
Sending SMS with AT Command recep_by GSM Programming & Reverse Engineering 15 09-07-2007 15:34
nokia 2280 Sending SMS via PC rinku_bindra CDMA Apple, CDMA BlackBerry, Nokia & Motorola 0 12-22-2003 19:38
Sending SMS with fixed dialling switched on (SIM-EMU) Paul M Sim Cloning and Scaning 1 06-26-2003 00:37
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.70440 seconds with 12 queries
