11-19-2009, 14:12 | #1 (permalink) |
Freak Poster Join Date: Sep 2009 Location: where the dreams live
Member: 1122148 Status: Offline Thanks Meter: 35 | nokia N70 showing dot on screen so pls sir any solution |
The Following User Says Thank You to shakil143 For This Useful Post: |
11-20-2009, 18:50 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | mate first try to search this forum before open a thread anyway here is your solution , but first try to change lcd with new one & check , if problem not solved then replace this filters.... |
11-21-2009, 16:10 | #3 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1163625 Status: Offline Thanks Meter: 1 | I have the same problem. i tried to search in the forum but i didn't find nothing similar to my issue. my n70 works (recieves and makes calls) but in the screen there are a lot of pixel blinking. is there any solution jumpering and removing? because i can't replace the ics thanks |
The Following User Says Thank You to bisont For This Useful Post: |
01-10-2010, 20:45 | #5 (permalink) |
No Life Poster Join Date: Apr 2009 Location: MobiCare, Mh-50, India
Member: 1019814 Status: Offline Thanks Meter: 653 | just get this.............. it works........http://www.4shared.com/file/18221472...ed_graphi.html |
The Following User Says Thank You to k_abhi For This Useful Post: |
01-11-2010, 03:48 | #6 (permalink) | |
Freak Poster Join Date: Apr 2007
Member: 494019 Status: Offline Thanks Meter: 159 | Quote:
The Following User Says Thank You to FIXXGSM For This Useful Post: |
N70 colurfull dot dot on screen | ahmad5175 | Nokia Hardware & Hardware Repair | 11 | 01-10-2010 19:56 |
nokia n70 showing white screen but with HWk CHACK n INFO IS OK | shakil143 | Nokia Hardware & Hardware Repair | 3 | 01-10-2010 19:41 |
V360 with dots on screen ... | sampat | Motorola Hardware Repair | 1 | 06-03-2007 03:32 |
Blackberry 7100v showing 543 on screen after flash | Colin | FuriousGold | 3 | 05-20-2007 23:37 |
mw3026 and myx-1 trio showing 3 on screen | GOODNESS | Infineon C16X M51 & ARM7 M52 BASED | 2 | 04-20-2006 16:58 |
