07-12-2008, 19:02 | #1 (permalink) |
Banned Join Date: Apr 2008 Location: washim Age: 36
Member: 754396 Status: Offline Sonork: [email protected] Thanks Meter: 913 | Help Hardware n70 dead SOLUTION |
The Following 4 Users Say Thank You to GSMONNITIN For This Useful Post: |
07-12-2008, 19:25 | #2 (permalink) |
Freak Poster Join Date: Jun 2005 Location: iran-kashan Age: 44
Member: 157053 Status: Offline Sonork: 100.1606219 Thanks Meter: 489 | say what is your problem.test your phone if connect with ufs3? connect to box remove autodetect product and click on check. post log. dont forget to say thanks. |
The Following User Says Thank You to morteza-icu For This Useful Post: |
07-13-2008, 15:29 | #3 (permalink) |
Member: 754396 Status: Offline Sonork: [email protected] Thanks Meter: 913 | nokia only nokia not boot pls help me |
07-13-2008, 15:37 | #4 (permalink) | ||
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | @GSMONNITIN Quote:
please explain your problem clearly | ||
The Following User Says Thank You to KK Mobile For This Useful Post: |
07-14-2008, 15:56 | #5 (permalink) |
Member: 754396 Status: Offline Sonork: [email protected] Thanks Meter: 913 | N70 Dead only nokia pls help me |
05-21-2009, 17:23 | #11 (permalink) |
Insane Poster Join Date: May 2009 Location: north india,,, himachal
Member: 1032503 Status: Offline Thanks Meter: 16 | n72 dead hi i got a prob wid n72,,, wen charging, thn u can power on... but otherwise it wont. pwr switch ok... jumper from near retu ic,,, checked but it still not power on until charger attached... plzzzz can u help??? |
05-22-2009, 14:15 | #12 (permalink) |
Member: 1032503 Status: Offline Thanks Meter: 16 | hi i got a prob wid n72,,, wen charging, thn u can power on... but otherwise it wont. pwr switch ok... jumper from near retu ic,,, checked but it still not power on until charger attached... plzzzz can u help??? [email protected] |
05-22-2009, 14:44 | #13 (permalink) | |
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Quote:
post results | |
05-23-2009, 09:46 | #14 (permalink) |
Member: 1032503 Status: Offline Thanks Meter: 16 | check voltage on power switch ? ? ? ? If voltage not come then change display ic right one . post results voltage is coming... i hav already tried that lcd ic jumper,,,still no success... let me post my prob again in detail... n thnx for replyn bro,,, wen i attach d charger, thn i swichnon d cell and thn it gets on n works fine,,, but if i attach d charger wen it is on, thn it says not charging,,, n later wen i switch off n thn try to on again, it wont until i attach d charger,,, d battery terminal shows 1.6v wen charger attached... means dat d cel charges or shows charging wen off,,, otherwise in on condition it says not charging,,, im very badly stuck up in this prob since two days,,, |
05-23-2009, 09:50 | #15 (permalink) |
Member: 1032503 Status: Offline Thanks Meter: 16 | check voltage on power switch ? ? ? ? If voltage not come then change display ic right one . post results i tried mate,,, but still it wont work,,, voltages r ok,,, |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
Pls. Help-nokia n70-dead showing the following problem | amit123 | Nokia Hardware & Hardware Repair | 21 | 08-14-2010 17:36 |
please help Nokia N70 mic solution | abote didier | Nokia Hardware & Hardware Repair | 2 | 07-29-2010 07:48 |
Help please, n70 dead? it only display a blank screen. | FabianAnarco | Nokia Base Band 5 ( BB-5 ) | 2 | 05-31-2007 17:47 |
Does anybody know to restore completely dead C 25 v 53? Hardware or software solution | Jurik | x1x to x45/x50 | 1 | 09-11-2000 12:49 |
