02-13-2009, 11:36 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: I N D I A(punjab) Age: 33
Member: 856059 Status: Offline Thanks Meter: 124 | Nokia n70 white display pro i have an 70 display pro his out going and in coming is ok and i change display but its show same i change his lcd ic but same i try search in forum but i did not find any one give new sol (plz help, thanks in advance) |
The Following User Says Thank You to Hitesh manocha For This Useful Post: |
02-13-2009, 12:50 | #9 (permalink) |
No Life Poster Join Date: Dec 2003 Location: philippines
Member: 45571 Status: Offline Thanks Meter: 45 | All my N70 display problem that can call in and out are solved by either display ic or LCD.Sometimes needs to be reflashed after changing LCD.Try to double check your placement of the display ic sometimes not aligned properly. |
02-13-2009, 12:58 | #10 (permalink) |
Member: 856059 Status: Offline Thanks Meter: 124 | i agree with you sir i also solve this pro in many n70 phones by changing display ic but in this phone i change two times display ic and also check all track and also change display jeck but pro not solved i am totaly confushed what is the fault in set i do everything in the end i think it is upp fault |
Nokia N70 White Display Solution | khisrow | Nokia Hardware & Hardware Repair | 15 | 06-26-2013 16:44 |
t 303 white display pro | naeem iqbal | Sony Ericsson Hardware Repair | 0 | 02-15-2010 08:22 |
nokia n70 white display | vaibhavdawar | Nokia Hardware & Hardware Repair | 3 | 09-08-2009 21:32 |
Nokia N70 White Display Hang | NIMESHFONOTLY | Nokia Hardware & Hardware Repair | 7 | 10-07-2008 15:46 |
n70 when power on blink nokia then white display | paraniselvanm | Nokia Hardware & Hardware Repair | 3 | 04-11-2008 09:19 |
