Nokia N73 Contact retailer I have a N73 phone when switch on it then coming phone start up failed contact retailer ........................i flash it with hwk box....but not clear..........................phone info is given below MCU SW : V 05wk47v61 09-07-08 RM-133 (c) Nokia. APE Core: V 4.0839.42.0.1 25-09-2008 RM-133 APE Var : V 4.0839.42.0.1-08 25-09-2008 RM-133 Product : Nokia N73 Prd.Code: 0543843 Bpr.Code: 0537044 Prod.Sn : CQE937904 HW Vers : 7200 APE HW : 1 APE Adsp: 256 EM VILMA: 15 EM BETTY: 22 RFIC Ver: 17211721 DSP Vers: scarfe_mc.05wk46v50p2 IMEI : 358973-01-628561-7 SL Serv : SIMLOCK SERVER VERSION 63 SL Conf : 000-00-00000000000 SL Prof : 0147196A00000000 SL Count: 00 00 SL Data Corrupted Provider: Not Found please help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee |
if you mxkey try to scan it and post the log to see the problem |
sorry brother i have no mxkey box............... |
ok full send mxkey full log |
please help me any one................for N73 |
bro try to unlock then write pm 1 and 309, |
@TS your SL data looks not good. Quote:
Dear just make a backup & complete erase phone then flash it after then pm 1 & 309 then unlock your prob will be solved..... |
Dear just make a backup & complete erase phone then flash it after then pm 1 & 309 and unlock.... your prob will be solved..... |
i will do that pm 1& 309...........but same problem................is it rethu problem........brother |
N73 write pm window Security block OK and saved to "RM-133_358973016285617_692011_40128 PM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) Additionaly, Checking HWC/CCC Certs... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9AA9792B2484904925E2A87C967A948EF1E35C24 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1D500213BAE0495054392B5F7AA98FFD20D4C388 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 Failed to send APE Secondary Loader -> Failed to get APE Configuration Data Prepare phone failed with message -> APE Secondary Boot Failed Analyze Security Error -> Failed to Boot / Prepare Phone Brother that is info window in cyclone box.....please help meeeeeeeeeeeeeeeeeeeeeeeeeeee |
you need unlock your mobile go to Security and click on Security analyze |
i wll do that on cyclone box................... |
SL Data Corrupted- this is the problem.. if you dont hane mxkey try the sl repair in bb5 unlocker free soft.. then unlock. hope it work. |
