Old 06-08-2011, 11:43   #1 (permalink)
Member: 946381
Thanks Meter: 150
Nokia N73 Contact retailer
I have a N73 phone when switch on it then coming phone start up failed contact retailer ........................i flash it with hwk box....but not clear..........................phone info is given below
MCU SW : V 05wk47v61 09-07-08 RM-133 (c) Nokia.
APE Core: V 4.0839.42.0.1 25-09-2008 RM-133
APE Var : V 4.0839.42.0.1-08 25-09-2008 RM-133
Product : Nokia N73
Prd.Code: 0543843
Bpr.Code: 0537044
Prod.Sn : CQE937904
HW Vers : 7200
APE HW : 1
APE Adsp: 256
EM VILMA: 15
EM BETTY: 22
RFIC Ver: 17211721
DSP Vers: scarfe_mc.05wk46v50p2
IMEI : 358973-01-628561-7
SL Serv : SIMLOCK SERVER VERSION 63
SL Conf : 000-00-00000000000
SL Prof : 0147196A00000000
SL Count: 00 00
SL Data Corrupted
Provider: Not Found
please help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
The Following User Says Thank You to zone3 For This Useful Post:
Old 06-08-2011, 11:52   #2 (permalink)
Member: 986942
if you mxkey try to scan it and post the log to see the problem
Old 06-08-2011, 12:13   #3 (permalink)
Member: 946381
Thanks Meter: 150
sorry brother i have no mxkey box...............
Old 06-08-2011, 12:13   #4 (permalink)
riyaz_deva's Avatar
Member: 565996
Thanks Meter: 13
ok full send mxkey full log
Old 06-09-2011, 06:42   #5 (permalink)
Member: 946381
Thanks Meter: 150
please help me any one................for N73
Old 06-09-2011, 07:13   #6 (permalink)
Member: 1028284
Thanks Meter: 19
bro try to unlock then write pm 1 and 309,
Old 06-09-2011, 08:38   #7 (permalink)
smorbe's Avatar
Member: 132735
Thanks Meter: 88
@TS
your SL data looks not good.
SL Data Corrupted
Provider: Not Found
if you dont have mxkey or any soft that can repair SL DATA i think you cant fix it.
Old 06-09-2011, 08:55   #8 (permalink)
sunnymobiles's Avatar
Member: 352633
Sonork: Sun Set Of The Life
Thanks Meter: 33
Thumbs down
Product : Nokia N73
Prd.Code: 0543843
Bpr.Code: 0537044
Prod.Sn : CQE937904
HW Vers : 7200
APE HW : 1
APE Adsp: 256
EM VILMA: 15
EM BETTY: 22
RFIC Ver: 17211721
SL Count: 00 00
SL Data Corrupted
Provider: Not Found
Dear just make a backup & complete erase phone then flash it after then pm 1 & 309 then unlock your prob will be solved.....
Old 06-09-2011, 08:56   #9 (permalink)
Member: 352633
Thanks Meter: 33
Thumbs down
Product : Nokia N73
Prd.Code: 0543843
Bpr.Code: 0537044
Prod.Sn : CQE937904
HW Vers : 7200
APE HW : 1
APE Adsp: 256
EM VILMA: 15
EM BETTY: 22
RFIC Ver: 17211721
SL Count: 00 00
SL Data Corrupted
Provider: Not Found
Dear just make a backup & complete erase phone then flash it after then pm 1 & 309 and unlock.... your prob will be solved.....
Old 06-09-2011, 11:28   #10 (permalink)
Member: 946381
Thanks Meter: 150
i will do that pm 1& 309...........but same problem................is it rethu problem........brother
Old 06-09-2011, 11:38   #11 (permalink)
Member: 946381
Thanks Meter: 150
N73 write pm window
Security block OK and saved to "RM-133_358973016285617_692011_40128 PM.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
-- SECURITY PROBLEM --
Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED!
To repair it, simply slick "SX4 Authorization / SD Repair" button.
After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically)
Additionaly, Checking HWC/CCC Certs...
Booting CMT...
APE_SYSTEM_ASIC_ID: 17100708
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: 9AA9792B2484904925E2A87C967A948EF1E35C24
APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000
APE_BOOT_ROM_CRC: 1DFD6613
APE_SECURE_ROM_CRC: 2C872FD4
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1D500213BAE0495054392B5F7AA98FFD20D4C388
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5
Failed to send APE Secondary Loader -> Failed to get APE Configuration Data
Prepare phone failed with message -> APE Secondary Boot Failed
Analyze Security Error -> Failed to Boot / Prepare Phone
Brother that is info window in cyclone box.....please help meeeeeeeeeeeeeeeeeeeeeeeeeeee
Old 06-09-2011, 12:24   #12 (permalink)
rizwankhan8670's Avatar
Member: 1497980
Thanks Meter: 1,266
you need unlock your mobile go to Security and click on Security analyze
Old 06-10-2011, 08:36   #13 (permalink)
Member: 946381
Thanks Meter: 150
i wll do that on cyclone box...................
Old 06-10-2011, 11:13   #14 (permalink)
Member: 986942
SL Data Corrupted- this is the problem.. if you dont hane mxkey try the sl repair in bb5 unlocker free soft.. then unlock. hope it work.
Page generated in 0.20667 seconds with 9 queries
