GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Nokia Hardware & Hardware Repair (https://forum.gsmhosting.com/vbb/f148/)
-   -   Nokia N79 Keypad Hang Solution.. (https://forum.gsmhosting.com/vbb/f148/nokia-n79-keypad-hang-solution-787026/)
basilbaby 07-14-2009 07:35
1 Attachment(s)
mehtabdecentmob 07-14-2009 07:37
good work keep it up bro...........
shahjee 07-14-2009 10:00
will test and post results ,
anyway thanks for good share
SMK 08-04-2009 13:34
From any board can get this IC N2850 ?
SMK 08-06-2009 16:55
Please is there an other Solution
all keypad hang after 2-3 second
gsmshare 08-06-2009 17:23
bro try to flash for hang,,,,,
basilbaby 08-08-2009 06:39
Try the above solution.. Good luck
SMK 08-08-2009 16:59
I did it & flash it but still the same
Dj King 08-08-2009 18:14
This is my solution. I already tested/proven three times already.
Remove the small square black ic at the back of the keypad membrane/assembly. Then try if the keypad still hangs after several secs/mins w/o the ic. Phone's keypads works normally even w/o this ic. Then post the result.
Br,;)
SMK 08-08-2009 23:55
Br,;)
I will try
do you main removing black IC forever or replace it ?
Now mobile is ok after changing keypad, but i will try your solution any way
SMK 08-09-2009 20:57
N79 Keypad Hang Solved
After removing the BLACK IC keypad now work fine
Dj King 08-10-2009 02:24
Thats great! So, we don't have to buy a brand new keypad assembly just to fix the phone. All you have to do is just remove the black ic and thats it. The real and simple solution. Now, the problem in n79 keypad issue is now resolved.
Br,;)
max414 08-21-2009 09:02
hey guys....its abdullah from pk
im in desperate help right here....i m having the same prob with my n79 and its been like 2 weeks now
the repairman i gave the cell toO has put out the indicated chip and now the keypad dosnt work at all
can u guys please tell me what exactly does this chip do?
can u please guide me that if i change the keypad assembly will it work??
cause i m totally clueless right now
the solution should have worked but it didn't
max414 08-21-2009 16:36
UPDATE
i got the ic removed and installed back in again
and now
THE KEYPAD DOES NOT WORK AT ALL!!!
help me out guyz
max414 08-21-2009 16:37
UPDATE
and now
help me out guyz
Page generated in 0.16603 seconds with 6 queries
