01-23-2012, 13:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Nokia N8 Format, Hard Reset to Factory Settings Procedures Uploaded with ImageShack.us This a simple instruction on how to factory reset the Nokia N8 and restores the phone to its original factory default settings. Factory reset through Menu Settings, this is only a soft reset and it restores all data to factory default. 1. From Main Menu go to Settings 2. Select Phone 3. Select Phone Management 4. Select Factory Settings then Delete Data and Restore Hard Reset Uploaded with ImageShack.us Hard Reset Note: This will delete all your applications installed and you may need to install it back again after the hard reset has been made. This is only advisable if you have a screen problem errors like, hang or frozen problems. So proceed with precautions. This is how to hard reset the Nokia N8 through button combination: * Turn off the phone. * Press and hold the following Button keys: o Volume Down button o Camera button o Menu button Press the Power button until the phone vibrates.... Once the process completes, the Nokia N8 will then reboot, any installed data or 3rd-party applications already wipe out. You may need to re-install it back again. |
The Following 2 Users Say Thank You to Momin_Telecom For This Useful Post: |
10-02-2013, 11:21 | #2 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Nepal
Member: 1294102 Status: Offline Sonork: 100.1655641 Thanks Meter: 79 | n8 hard reset not done hard reset not done by this process volume - camera menu power button i pressed these buttons simultaneously until phone vibrates but hard reset not done my set is locked by user code. what to do??????????? |
Nokia n8 offline mode | .::PHONECRAKER::. | Nokia Hardware & Hardware Repair | 5 | 07-12-2012 14:22 |
nokia 5800 mmc curapted problem help...... | humax_z | Nokia Hardware & Hardware Repair | 4 | 06-27-2012 05:43 |
