10-17-2012, 16:50 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: JESSORE.BD
Member: 1054255 Status: Offline Sonork: BISMILLAH.M.S.CENTER Thanks Meter: 92 | Nokia n8 hang on logo help FULL FALSH BUT SAME MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C080418B Using device: USB ROM and HTI, FW ver: 00.50, SN: 00003E4C Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 070001058AD403443E2F1DED8EB838DB7F09CA22 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2745A972 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 Original Imei: 35791904894168 Original Product code: 0599436 Bluetooth ID: 6CA780488D3E SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1D8 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia N8-00 USB Phonet, PORT_ID: FAB60A9 Verifying communication to device OK. Phone type: RM-596 (Nokia N8-00) SW version: V 79_sr1_11w42.7 03-04-12 RM-596 (c) Nokia ApeCoreSw: 111.030.0610 Imei plain: 35791904894168-6 Product code: 0599436 Battery voltage: 4088 mV, current: 126 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed "C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-596" folder created. Imei net: 357919048941686 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
10-17-2012, 18:09 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Saudi Arabia
Member: 615730 Status: Offline Thanks Meter: 256 | Brother its Hardware fault, Reheat the RAPUYAMA carefully then post result.. |
The Following User Says Thank You to Sagitarious For This Useful Post: |
