04-08-2013, 08:33 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: bilara
Member: 959485 Status: Offline Thanks Meter: 16 | nokia n8 power on problem Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 1F3002156CA20344CF6CF0989A6AEE00BF70144A CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C663DC1 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x178 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35268404378906_CE RT.rpl" CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 228.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT SOS+DECOMP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent CMT GENIO_INIT block sent CMT SOS+IVE3A block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 22.188 s Processing PPM file: RM-596_111.040.1511_24.01_India_79u_prd.rofs2.fpsx [BB5,XSR 1.6] size: 34.69 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 64.25 MB CMT FLASH,MuxOneNAND area [09A40000-0DA7FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 6.375 s Processing PPM file: RM-596_111.040.1511_C03.01_India_79u_prd.rofs3.fpsx [BB5,XSR 1.6] size: 24.97 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15.16 MB CMT FLASH,MuxOneNAND area [01378000-0139FFFF] CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF] Flash programming ... CMT SOS+ROFS3 block sent CMT SOS+IVE3B block sent Programming completed in 0.047 s Processing CNT file: RM596_APE_ONLY_ENO_11w36_v0.162.fpsx [BB5,XSR 1.6] size: 4.38 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.828 s Processing CNT file: RM-596_111.040.1511_U03.01_79u.uda.fpsx [BB5,XSR 1.6] size: 119.13 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 262 MB CMT FLASH,MuxOneNAND area [0EA00000-1EFFFFFF] Flash programming ... Programming completed in 17.609 s Total time for flashing process(boot+erase+write) was 1 min 9.937 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C663DC1 Waiting for USB device removal ... Device connected: nmwcdc\Nokia N8-00 USB Phonet, PORT_ID: 2634A122 Verifying communication to device OK. Phone type: RM-596 (Nokia N8-00) SW version: V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia ApeCoreSw: 111.040.1511 Imei plain: 35268404378906-9 Product code: 0599278 Battery voltage: 3765 mV, current: 97 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352684043789069 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
06-17-2013, 06:17 | #2 (permalink) |
Crazy Poster Join Date: May 2009 Age: 36
Member: 1042203 Status: Offline Thanks Meter: 46 | check power button here is Nokia N8 Power Button Ways Solution Nokia N8 Power Button Ways Problem Solution |
