Old 12-13-2017, 15:59   #1 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 2,268
nokia n8 rm 596 usb cable symbol flashing
hi
device ask for connecting USB Cable
and usb cable keep blinking
Old 12-14-2017, 09:44   #2 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 2,268
i fixed issue thru cleaning
but got another problem
when i insert sim card and switch on phone
fhone ask for switching from no connection to general
and sim contact detected
once and before network line work
its reboot
Old 12-15-2017, 18:12   #3 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,329
what was the condition when you receive the unit ? seems it's water logged ! try to flash youe set then check .
post here flashing log along with selftest result . and don't send me pm .
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 12-15-2017, 18:24   #4 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 2,268
flashed it
same issue
Connect phone on selected interface...
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : RM-596_025.007_79.92_prd.core.fpsx
PPM : RM-596_025.007_10.01_Hebrew_79.92_prd.rofs2.fpsx
PPM2 : RM-596_025.007_00.01_79.92_prd.rofs3.fpsx
CNT : RM-596_025.007_U01.01_79.92.uda.fpsx
APE : RM596_APE_ONLY_ENO_11w15_v0.148.fpsx
Flashing phone now...
[Gen] Rules accepted for : RAPUxx Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Connection opened successfully
Waiting for communication response...
[BootRom] : 1st boot Ok!
ASIC ID: 000000030000022600010007600C192102031104
CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00000C35
EM1 ID: 00000C30
PUBLIC ID: 197001020AA70344DF4772C0FBA069661CBBC157
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0
Processing RAWLOADER...
FLIC : 005000EC
Req : XSR 1.6
Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:03
Reopening the connection...
Waiting for response: 30
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231
ADL: phone is in flash mode
Backup enabled, will read all certificates...
Reading NPC certificate...
IMEI : 355944042076117
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\355944042076117_CR T.rpl
=== SW Version Check ===
- > UPGRADE
===Flashing [MCU]===
Erase : Processing RM-596_025.007_79.92_prd.core.fpsx
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:01
Write : Processing RM-596_025.007_79.92_prd.core.fpsx
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [SOS+PMML]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [SOS*UPDAPP]
CMT: Writing Hash CERT [SOS*DSP0]
CMT: Writing Hash CERT [LDSP]
CMT: Writing Hash CERT [SOS*ISASW]
CMT: Writing Hash CERT [SOS+CORE]
CMT: Writing Hash CERT [SOS+ROFS1]
Total writen 514 blocks
TIME : Write time : 00:00:20
MCU Write done
ADL: Request programm status
NAND status : 00000002 / 00000002 / 00000000
===Flashing [PPM]===
Erase : Processing RM-596_025.007_10.01_Hebrew_79.92_prd.rofs2.fpsx
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing RM-596_025.007_10.01_Hebrew_79.92_prd.rofs2.fpsx
CMT: Writing Hash CERT [SOS+ROFS2]
Total writen 200 blocks
TIME : Write time : 00:00:08
PPM Write done
===Flashing [PPM2]===
Erase : Processing RM-596_025.007_00.01_79.92_prd.rofs3.fpsx
Erasing....
Erasing Ok...
Write : Processing RM-596_025.007_00.01_79.92_prd.rofs3.fpsx
CMT: Writing Hash CERT [SOS+ROFS3]
Total writen 2 blocks
TIME : Write time : 00:00:00
PPM Write done
===Flashing [CNT]===
Erase : Processing RM-596_025.007_U01.01_79.92.uda.fpsx
Erasing....
Erasing Ok...
Write : Processing RM-596_025.007_U01.01_79.92.uda.fpsx
Total writen 363 blocks
TIME : Write time : 00:00:11
CNT Write done
===Flashing [APE]===
Erase : Processing RM596_APE_ONLY_ENO_11w15_v0.148.fpsx
Erasing....
Erasing Ok...
Write : Processing RM596_APE_ONLY_ENO_11w15_v0.148.fpsx
CMT: Writing Hash CERT [SOS*ENO]
Total writen 18 blocks
APE Write done
ADL: Close_Session
Content: 000300000000020000000200000000
ADL: Reboot
Flashing done!
Total flash time : 00:00:44
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia N8-00
Software Info: V 92_11w37 14-09-11 RM-596 (c) Nokia
IMEI: 355944042076117
Ape Version: 025.007
Product code: 059C8T6
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Resetting LifeTimer
Reset Done!
Battery voltage is enough for start
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Elapsed: 00:01:39
Phone found!
Series 60 Device detected!
read info... - Ok
Phone disconected!
Phone found!
read info... - Ok
Phone disconected!
i notice this
if i put phone to charger and sim
everything ok
with sim and without charger phone switch off
Old 12-15-2017, 18:44   #5 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 2,268
Initializing Tests...
IMEI : 355944042076117 , Phone : RM-596 Nokia N8-00
Get keys...
PASSED | ST_SLEEP_X_LOOP_TEST
PASSED | ST_UEM_CBUS_IF_TEST
PASSED | ST_EAR_DATA_LOOP_TEST
PASSED | ST_SIM_CLK_LOOP_TEST
PASSED | ST_SIM_LOCK_TEST
PASSED | ST_SECURITY_TEST
PASSED | ST_PWR_KEY_TEST
PASSED | ST_CURRENT_CONS_TEST
PASSED | ST_HOOKINT_TEST
PASSED | ST_BTEMP_TEST
PASSED | ST_MBUS_RX_TX_LOOP_TEST
PASSED | ST_KELVIN_BATVOLTAGE_TEST
PASSED | ST_KELVIN_VIBRA_TEST
PASSED | ST_KELVIN_CAPACITOR_TEST
PASSED | ST_KELVIN_MISC_TEST
PASSED | ST_KELVIN_AUDIO_TEST
PASSED | ST_KELVIN_XEAR_TEST
PASSED | ST_AMB_LIGHT_SENSOR_TEST
PASSED | ST_USB_CHARGING_TEST
PASSED | ST_DIGIMIC_TEST
PASSED | ST_HEADSET_AMPLIFIER_TEST
PASSED | ST_LED_CONTROLLER_TEST
PASSED | ST_AUDIO_PLL_TEST
PASSED | ST_RAM_IF_TEST
PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST
PASSED | ST_CDSP_RF_BB_IF_TEST
PASSED | ST_CDSP_STROBE_TEST
PASSED | ST_CDSP_DIGI_RXTX_IF_TEST
PASSED | ST_CDSP_RF_SUPPLY_TEST
PASSED | ST_CDSP_PA_ID_PIN_TEST
NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST
SelfTests end
Old 12-16-2017, 18:31   #6 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,329
flashing and selftest result log seems ok , connect phone with external psu and check current consumption (in tx mode) .
Page generated in 0.28087 seconds with 7 queries
