05-09-2007, 11:07 | #1 (permalink) |
Junior Member Join Date: Apr 2004 Age: 41
Member: 63119 Status: Offline Thanks Meter: 2 | Nokia N91 Hang i'am having one noikia N91 the problem is when we put the batt cover the handset goes hang, i think that there is some problem in hard disk without cover it works fine is there any code to format hard disk ? reply guys thanks in advance |
05-09-2007, 14:36 | #6 (permalink) | |
Member: 63119 Status: Offline Thanks Meter: 2 | n91 goes hang Quote:
thx | |
05-09-2007, 15:53 | #7 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | Hi ! TECHNOTRONIX !! It's no manhetic at all. It's hard drive problem U have to change it.Only this way can solve Ur problem.See the picture. |
05-09-2007, 17:33 | #8 (permalink) | |
No Life Poster Join Date: Nov 2005
Member: 200145 Status: Offline Sonork: 100.1596786 Thanks Meter: 677 | Quote:
hahahaha...i thought somethng special inside ur attachment!!! foo...simply d hard disk image... nice tips &attachment my frnd keep going this way | |
05-10-2007, 08:20 | #9 (permalink) |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | u mentioned clearly ur hard disk is defective ,it may be defective by installing wrong software or any other hardware fault ,first check with the new one after that u can easily get what is the real problem .if the new one shows same then the fault is in ur board . |
06-01-2007, 01:04 | #11 (permalink) |
No Life Poster Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | well for thoose who can't reach new hard drive like i couldn't follow these steps.might just work for you too 1. remove back cover and restart phone 2. enter menu and navigate to hard drive (should be menu>tools>harddrive) 3. Ignore 'hard drive not found' error message and click 'options' 4. while options still displayed, replace harddrive back cover and wait(wait is gonna depend on how bad ur drive is) 5. after a few minutes, phone would go white screen and reboot to 'hard drive not formatted' error 6. format drive first shoud take about 15mins(use charger while formatting). At the end you can now go and check hard drive as usual. once again this time click options and format fully ,another 15minutes wait. then all should be well! post results dudes regards ndagi |
07-02-2007, 05:42 | #13 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i have n91 in which the problem is , it restarts after the set is fully started ... i have also tried not to use the battery cover but same problem remains .. i have flashed the set , what could be the problem ? help.. thanks |
11-06-2008, 07:56 | #15 (permalink) |
Junior Member Join Date: Mar 2008
Member: 737754 Status: Offline Sonork: [email protected] Thanks Meter: 3 | hello sir i have n91 rm 158 white light i flashed it,now it is nokia hang any soulation for it please help me... |
nokia N91 hang @ retart | MR.MAMUN | Nokia Base Band 5 ( BB-5 ) | 0 | 03-21-2010 11:51 |
Nokia N91 Hanging | 4 u man | J.A.F. By Jafsupport.com | 1 | 07-30-2008 19:07 |
N91 Hang on Nokia | Master-GSM | Nokia Base Band 5 ( BB-5 ) | 10 | 01-18-2007 19:14 |
nokia n91 hang problem | nomi | Nokia Hardware & Hardware Repair | 3 | 10-01-2006 18:07 |
n91 hang nokia | sepid | Nokia Base Band 5 ( BB-5 ) | 1 | 08-02-2006 17:45 |
