NOKIA N95 charging only 1 volt output hi , i have a nokia n95 . when i put it for charge its says charging but never charges . when i check the voltage in battery connectors it shows 1 volt in the multimeter . can anyone elp me with this . would be a great help . and i use original battery and the charger . |
Change BETTY IC for charging problem |
THANKS !!! YOU so much for this . will try |
http://img36.imageshack.us/img36/212...ingnotsave.jpg |
thank you ashad for the pic . will try this and confirm later .. |
is this problem already solved? |
