01-27-2008, 10:31 | #1 (permalink) |
Junior Member Join Date: Nov 2007
Member: 629626 Status: Offline Thanks Meter: 0 | Nokia N95 Keypad Problem I have a problem with my Nokia N95. Its Keypad is not working. sometimes some keys are worked. when I press 8 and * then *,p,w,+ are shown. other keys are not working. when i press other keys the display is changed without downside menus. sometimes this will occur opposite. And also my battery charge is becoming low very quickly. please help me with this. also give me the picture for the solution. thanks. |
05-22-2011, 16:03 | #8 (permalink) |
Insane Poster Join Date: Dec 2008
Member: 932171 Status: Offline Sonork: 2244 Thanks Meter: 11 | nokia n95 key pad not working in my hand 1 nokia n 95 key pad not working i change keypad ic fex cable reemove side swich but same problem key pad upper and down not working plese any body konw give me a sloution |
09-18-2012, 11:54 | #9 (permalink) |
No Life Poster Join Date: Sep 2005 Location: London, UK
Member: 178513 Status: Offline Thanks Meter: 109 | Hello, before to change any IC try a simple solution, disassembly the LCD part, check the connector of LCD if was mounted not correctly or if the phones was shaked maybe the flex change possition. if not try new flex, the main flex that connect mainboard with LCD and small camera. Wbr, Albelektronik. |
Nokia N95 Keypad key pad problem | serjer | Nokia Hardware & Hardware Repair | 16 | 05-23-2012 20:23 |
Nokia N95 keypad problem..... | tutu1982 | Nokia Hardware & Hardware Repair | 5 | 06-29-2010 12:32 |
nokia n95 keypad light not working | khurram19 | Nokia Hardware & Hardware Repair | 9 | 03-04-2010 06:40 |
nokia n95 keypad problum | BCcommunication | Nokia Hardware & Hardware Repair | 8 | 07-08-2009 08:50 |
Nokia N95 Keypad Problem | desi0067 | Nokia Hardware & Hardware Repair | 3 | 02-24-2009 19:02 |
