04-03-2010, 11:26 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Irvinestown
Member: 719399 Status: Offline Thanks Meter: 228 | Nokia n95 not switching on Here I have nokia n95 which doesn't turn on at all. The battery is ok as I checked other battery. I disassembled the phone and seems allright. When connecting via fbus cable to Jaf, phone turns on and works- but when try to use with battery I can't turn on the mobile phone. Can somebody help? |
04-03-2010, 11:38 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Quote:
if ok then replace avilma. | |
The Following User Says Thank You to mahbubalfa For This Useful Post: |
04-03-2010, 13:47 | #8 (permalink) |
Freak Poster Join Date: Mar 2010 Location: ***INDIAN***
Member: 1268409 Status: Offline Thanks Meter: 57 | Check this methode dear, press power button ,then u check out put voltage v.core(1.8v),v.io(1.8v),v.aux ,this volatges ok ,u check slw,,,,,post the result..... |
The Following User Says Thank You to ANILMPLY For This Useful Post: |
04-03-2010, 18:26 | #12 (permalink) |
Member: 719399 Status: Offline Thanks Meter: 228 | I decided to buy a mobo hence I'm not sure. The cost of mobo is 32 pounds The cost of multimeter and avilma is about 20 pounds and I'm not sure if it solves. |
04-03-2010, 18:29 | #13 (permalink) |
Member: 719399 Status: Offline Thanks Meter: 228 | I decided to buy a mobo hence I'm not sure. The cost of mobo is 32 pounds The cost of multimeter andavilma is about 20 pounds and I'm not sure if it solves. THANK YOU ALL !!!! YOU ARE GREAT !!! |
04-17-2010, 00:28 | #14 (permalink) |
Member: 719399 Status: Offline Thanks Meter: 228 | Mobo bought and guess what? Most of the mobo components(mainly switches) bought are lost(desoldered from the board).Don't you even try allegro website-keep away it's like area 51. To reball honestly in NI I don't see anyone. 35 pounds lost. Problem still not solved. But anyway thanks for your help |
nokia 2630 not switching on | pathricko | Nokia Hardware & Hardware Repair | 1 | 02-18-2009 11:38 |
nokia 3410 not switching on | nellabe | Nokia Hardware & Hardware Repair | 1 | 06-04-2007 10:32 |
n95 proto does not switch on | psych0 | Nokia Hardware & Hardware Repair | 1 | 04-30-2007 22:00 |
Nokia 6630 not switching on not charging help | edongzkisiete | Nokia Base Band 5 ( BB-5 ) | 0 | 01-05-2007 10:17 |
Nokia 3310 not switching on even after flashing | supremegsm | Nokia Hardware & Hardware Repair | 11 | 04-14-2003 18:46 |
