01-22-2010, 20:50 | #1 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | nokia n96 black screen problem is mirror the phone work fine. i changed the 2 display ics but same problem i tested bord on ather display and another flex but still same problem so the problem in board not display and not flex cable so if any one have solution please post here . |
The Following User Says Thank You to yarra For This Useful Post: |
07-10-2011, 09:14 | #3 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1613336 Status: Offline Thanks Meter: 0 | The Nokia N96 screen behaves funny if you set the contrast to maximum in the settings. In my case it started to turn the screen black and it did not light up if I pressed any key (as I expected it to). When I went to settings, phone, ..., display and set the contrast back a little from the maximum the functionality was restored. You can try this or reset to factory settings. This should fix the problem. |
Nokia N81 8gb screen problem, artifacts and black screen.. | DjDecibel | Nokia Hardware & Hardware Repair | 8 | 01-03-2011 18:15 |
n96 white screen problem need help | yapanit | Nokia Base Band 5 ( BB-5 ) | 1 | 02-28-2010 10:55 |
Nokia N96 - White Screen | someone2408 | Nokia Base Band 5 ( BB-5 ) | 2 | 02-10-2010 02:08 |
(( n96 black screen after power ON )) | saiftc2 | Nokia Base Band 5 ( BB-5 ) | 0 | 01-26-2010 02:24 |
N96 Black screen,, help | Bourne_13 | Nokia Base Band 5 ( BB-5 ) | 3 | 11-25-2009 10:15 |
