04-01-2008, 18:23 | #1 (permalink) |
Banned Join Date: Dec 2006 Location: inside of infinity best tool
Member: 411831 Status: Offline Thanks Meter: 215 | 3250 nokia memory card problem i have nokia 3250, all ok but show "memory card not inserted" i check switch, it is ok, sometimes it show memory card, some times show memory card corrupted. i change memory ic (small crystal) also same, but some times it work fine. what i do? if remove switch, it work? if remove switch need jumper? if yes please help. A LOT OF THANKS |
The Following User Says Thank You to msantar For This Useful Post: |
04-01-2008, 18:51 | #2 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 706300 Status: Offline Thanks Meter: 147 | re: Quote:
The Following User Says Thank You to mobilespeed For This Useful Post: |
04-02-2008, 05:33 | #3 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | Quote:
remove try this solution i think it helpful for you | |
The Following 2 Users Say Thank You to jimm07ct For This Useful Post: |
04-02-2008, 08:14 | #6 (permalink) | |
" bro i already i posted itz not ur pic so it wasnt for u the logic behind it is simple check schematics & u will find the ways of it r not the same as sim ic dont get me wrong & itz 100% wrong solution" | |
04-02-2008, 08:28 | #8 (permalink) | |
dont mind some of us post what he dont know about solution check the link http://www./showth...light=3250+mmc you say 100% wrong solution do you test it? | |
The Following User Says Thank You to jimm07ct For This Useful Post: |
04-02-2008, 08:32 | #9 (permalink) | |
no need to answer me i think now you can understand your faul talk if you dont know what is right or wrong ,then you not need to command best of luck | |
04-02-2008, 08:40 | #10 (permalink) | |
" not expected from u these type of words the simple example is of 6600 tell me have u tried ever the same jumper for 6600 if yes tell me wt was the result if no then check any time in near future & check the schematics of ics in both cases (3250 & 6600),one more thing brother when i post i know wt i post. the question is not he or they says it works the question is i say or u say it works then only we have a right to post thanx --- do reply" | |
04-02-2008, 09:03 | #11 (permalink) | |
one thing all of solution we found from other person when we try this then we can get result. and 6600 and 3250 are not same case. you say 100% wrong solution i think you can find your fault | |
04-02-2008, 09:08 | #12 (permalink) | ||
04-02-2008, 09:22 | #13 (permalink) |
Member: 706300 Status: Offline Thanks Meter: 147 | re: Originally Posted by jimm07ct bro, one thing all of solution we found from other person when we try this then we can get result. and 6600 and 3250 are not same case. you say 100% wrong solution i think you can find your fault " u will find no solution in this thread for my query becz i m 100% right, now the logical point for u if i replace the same ic with the ic of 6600, wt will be the result. plz be practical & do reply other members r also welcomed, with love" |
04-02-2008, 11:47 | #15 (permalink) |
Member: 706300 Status: Offline Thanks Meter: 147 | re: Originally Posted by jimm07ct bro, one thing all of solution we found from other person when we try this then we can get result. and 6600 and 3250 are not same case. you say 100% wrong solution i think you can find your fault " where r u brother waiting for ur reply so that i could learn more related to this topic" |
3250 memory card problem | jmustufa | Nokia Hardware & Hardware Repair | 4 | 05-08-2011 13:01 |
nokia 6233 memory card problem | .::Moby World::. | Nokia Hardware & Hardware Repair | 1 | 03-11-2009 14:59 |
3250 "no memory card inserted"!!! | AswanX | Nokia Base Band 5 ( BB-5 ) | 1 | 07-06-2007 05:53 |
Problem 3250 wuth memory card | Callen | Nokia Hardware & Hardware Repair | 6 | 06-30-2007 12:00 |
3250 no memory card inserted | HUM | Nokia Hardware & Hardware Repair | 5 | 01-17-2007 20:58 |
