Old 01-06-2011, 11:41   #1 (permalink)
Member: 180833
Sonork: 100.1578281
Thanks Meter: 217
Nokia N97 Only Vibrate
When i receive the phone then it was dead.
After flashing, the phone is only vibrate.
There is nothing on display. Set has no response.
I change the LCd And Rebon. But nothing changed.
Hope some one ill suggest me ...
Version from phone: v
Version from file: 22.0.110
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B21
PUBLIC ID: 10400117DDDA0158138B77BEABD5F7FB51E69A48
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
 SecondaryBoot: RAPIDOv11_2nd.fg [BB5]  version: 1.37.1 revision: 0.0 size: 0x3B80
 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040  - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
 Algorithm: RAPIDOv11_algo.fg [XSR 1.5]  version: 1.40.0 revision: 0.0 size: 0x27520
CMT PAPUBKEYS HASH: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B
TransmissionMode: DDR&TX2
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Flash Imei: 35606403202910
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35606403202910_BACK.rpl"
Processing MCU file: RM-505_22.0.110_prd.core.C00
 [BB5,XSR 1.5]  size: 106.34 MB
 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 167.44 MB
CMT MuxOneNAND area [00040000-00082FFF]
CMT MuxOneNAND area [00083400-003FFFFF]
CMT MuxOneNAND area [00800000-00D5FFFF]
CMT MuxOneNAND area [00D60000-0AB9FFFF]
Formating Partition ...
erased in 0.938 s
Flash programming ...
CMT PAPUBKEYS: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B (RAP Certificate 166 v.1) written.
Programming completed in 9 min 10.922 s
Processing PPM file: RM-505_22.0.110_prd.rofs2.V01
 [BB5,XSR 1.5]  size: 24.12 MB
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
Erase size: 35.00 MB
CMT MuxOneNAND area [079A0000-09C9FFFF]
erased in 0.203 s
Programming completed in 2 min 8.610 s
Processing PPM file: RM-505_22.0.110_C01_prd.rofs3.fpsx
 [BB5,XSR 1.5]  size: 9.01 KB
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
Erase size: 15.00 MB
CMT MuxOneNAND area [09CA0000-0AB9FFFF]
erased in 0.110 s
Programming completed in 0.312 s
Processing CNT file: RM505_APE_ONLY_ENO_09w23_v0.072.fpsx
 [BB5,XSR 1.5]  size: 2.75 MB
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
Erase size: 4.00 MB
CMT MuxOneNAND area [00400000-007FFFFF]
erased in 0.047 s
Programming completed in 14.813 s
Processing CNT file: RM505_507_22.0.110_uda_1_001.uda.fpsx
 [BB5,XSR 1.5]  size: 8.79 MB
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
Erase size: 75.50 MB
CMT MuxOneNAND area [0ABA0000-0F71FFFF]
erased in 0.438 s
Programming completed in 46.734 s
Total time for flashing process(boot+erase+write) was 13 min 3.282 s
Flashing completed in 14 min 2.984 s
Phone Type: RM-505 (Nokia N97)
SW Version: V ICPR72_09w44.18 28-05-10 RM-505 (c) Nokia
Imei plain: 35606403202910-6
Product Code: 0576350
ApeCoreSw: v 22.0.110
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3560640320----
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Here is the Self Test Log :
Phone Type: RM-505
SW version: V ICPR72_09w44.18 28-05-10 RM-505 (c) Nokia
ID        Test name                       Startup   Result
88   TAHVOINT                      Y          passed
46   UEM_CBUS_IF                   Y          passed
3    EAR_DATA_LOOP                 Y          !failed !
12   SIM_CLK_LOOP                  Y          passed
13   SIM_IO_CTRL_LOOP              Y          passed
33   SIM_LOCK                      N          passed
93   SECURITY                      N          passed
90   PWR_KEY                       N          passed
2    CURRENT_CONS                  N          passed
20   BACKUP_BATT                   N          passed
96   HOOKINT                       N          passed
101  BTEMP                         N          passed
8    MBUS_RX_TX_LOOP               Y          passed
32   AMB_LIGHT_SENSOR              N          passed
122  FMTX                          N          !NOT EXECUTED(03)
117  DIGIMIC                       N          !NOT EXECUTED(03)
108  EXT_DEVICE                    N          !NOT EXECUTED(03)
56   CDSP_SLEEPCLK_FREQ            N          !NOT EXECUTED(03)
128  CDSP_SLEEPCLOCK_FREQ          N          !NOT EXECUTED(03)
86   CDSP_RF_BB_IF                 N          !NOT EXECUTED(03)
83   CDSP_RF_SUPPLY                N          !NOT EXECUTED(03)
85   CDSP_TX_IQ                    N          !NOT EXECUTED(03)
74   CDSP_TXC_DATA                 N          !NOT EXECUTED(03)
79   CDSP_RX_PLL_PHASE_LOCK        N          !NOT EXECUTED(03)
80   CDSP_TX_PLL_PHASE_LOCK        N          !NOT EXECUTED(03)
75   CDSP_WCDMA_TX_POWER           N          !NOT EXECUTED(03)
81   CDSP_RX_IQ_LOOP_BACK          N          !NOT EXECUTED(03)
77   CDSP_GSM_TX_POWER             N          !NOT EXECUTED(03)
7    KEYBOARD_STUCK                N          !NOT EXECUTED(03)
21   LPRF_IF                       N          !NOT EXECUTED(03)
22   CAMERA_IF                     N          !NOT EXECUTED(03)
5    CAMERA_ACCELERATOR            N          !NOT EXECUTED(03)
37   SEC_CAMERA_IF                 N          !NOT EXECUTED(03)
121  LED_FLASH                     N          !NOT EXECUTED(03)
38   CAMERA_AUTOFOCUS              N          !NOT EXECUTED(03)
44   LPRF_AUDIO_LINES              N          !NOT EXECUTED(03)
59   MAIN_LCD_IF                   N          !NOT EXECUTED(03)
60   TOUCH_STUCK                   N          !NOT EXECUTED(03)
71   BT_WAKEUP                     N          !NOT EXECUTED(03)
72   WLAN                          N          !NOT EXECUTED(03)
92   BT_WLAN_COEXISTENCE           N          !NOT EXECUTED(03)
97   MASS_MEMORY_IF                N          !NOT EXECUTED(03)
103  TOUCH_IF                      N          !NOT EXECUTED(03)
104  ACCEL_IF                      N          !NOT EXECUTED(03)
113  LCD_CONTROLLER                N          !NOT EXECUTED(03)
49   VIBRA                         N          !NOT EXECUTED(03)
91   USB_LOOP                      N          !NOT EXECUTED(03)
42   RADIO                         N          !NOT EXECUTED(03)
115  TVOUT_IF                      N          !NOT EXECUTED(03)
114  IO_EXPANDER_IF                N          !NOT EXECUTED(03)
201  MAGNETOMETER                  N          !NOT EXECUTED(03)
Old 01-06-2011, 11:52   #2 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
Partitioning ...OK
erased in 0.938 s
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
erased in 0.203 s
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
erased in 0.110 s
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
Erase size: 4.00 MB
erased in 0.047 s
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
erased in 0.438 s
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Phone Type: RM-505
90   PWR_KEY                       N          passed
96   HOOKINT                       N          passed
101  BTEMP                         N          passed
Bro.try this solution.
http://forum.gsmhosting.com/vbb/f148...ashad-1114142/
Old 01-06-2011, 12:30   #3 (permalink)
Member: 180833
Sonork: 100.1578281
Thanks Meter: 217
Originally Posted by ashad420 View Post
Bro, Thanks for ur reply.
Trying to make this Jumper, but nothing change .
Old 07-20-2013, 20:54   #4 (permalink)
Member: 1455744
same problem. jumper helps till next restart and now it dont work.
Old 07-23-2013, 10:39   #5 (permalink)
Member: 516628
Thanks Meter: 9
bro, finaly whats solution for this
Old 07-23-2013, 12:25   #6 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
Check Batt BSI line if is connected .
Page generated in 0.35999 seconds with 9 queries
