Nokia voice encryption device project 1 Attachment(s) Hi there guys ! Yesterday, I had a project ideea. I thought about a gsm encryption device. The A5 algorythm is safe enough for a lame hacker who want to tap a conversation over the air, but the guys from the phone company can listern to you quite easy. So , why not building a few crypting devices, and double encoding the communications between a few phones ... I thought about two methods of doing this. 1. The encoding device can be inside the phone, inserted between the A/D D/A converter and the main processor, where the digital signal is A5 encrypted.I studied Nokia 3310 schematic, and found out quite interesting things. COBBA asIC provides an interface between the baseband and the RF circuitry . COBBA performs A/D conversion of the analog signal comming from the microphone, and fr the transmit path COBBA performs D/A conversion.COBBA is connected with the main processor MAD2WD1 with two serial interfaces, one for transferring rx/tx signals between MAD2WD1 and COBBA, and one for transferringcodec Rx/Tx samples.I thought about cutting the PCM samples lines ( rx and Tx ) and inserting a microcontroller programmed to crypt theese samples. As you can see in the pictures, on theese lines there are four fumpers ... so I think that can access these lines, somewhere on the surface of PCB, without desoldering MAD2 or COBBA. If someone knows where theese jumpers are located on the PCB please feel free to mail me. 2.The encoding device can be done outside the phone, conected at Rx/Tx on the external accessory connector, and the call will be in fact a data type call. But this in far more complicated.I have an ideea doing this, but I would prefer the first way. If someone is interested in this project and can help somehow, please feel free topost here . Thank you |
... and MAD_2 1 Attachment(s) z |
thats wery nice but i dont think for you to make this try to find this lines on defect pcb and cut them than put tini wire to botom conector for headphones cut this lines to to prevent shortcircuit than you can use your project. but the best way is that you use your project outside the phone with headphones and ext mic(just conect mic and speaker to project and other phone also so you dont need to cut any wire) |
I don't think so ... I don't want to make an analog encryption. I want digital...so I have to code a digital signal. Let's say that I convert an analogue signal from external mic to digital, I Xor the signal with some noise , and then I convert it back to analogue to send it via mic. phone input. It won't be good, because of the mic line bandwidith. I don't like either the internal device sollution, I want some external device, but... it seems that I don't have a choice.Any other ideeas ? |
