Old 06-22-2012, 07:08   #1 (permalink)
sangaistalin's Avatar
Member: 1474141
Sonork: 100.1647675
Thanks Meter: 66
nokia 1616 rh-125 14 BAD RSA SIGNATURE
hai brother i have one nokia 1616 i full flashed that phone the phone working ok
but white display show, but in file info that show lcd
MCU SW : V 05.80 06-08-10 RH-125 (c) Nokia
PPM SW : V 05.80 06-08-10 RH-125 (c) Nokia EL
Platform: Infineon
Prd.Code: 0595840
Bpr.Code: 059F8R0
Prod.Sn : 9683C76AI
HW Vers : 1014
UEM : 1328
UPP : 8850 [2292]
LCD Type: WIN:BAFFINv80 NT39121
IMEI : xxxxxxxxxxxxxxxxxxxxxxxx
SL Conf : 001-01-00000000000
SL Prof : 000000000003000-2
SL Var : 00003578760458753300
SL Aux : 000B0000
HW Sig : 5ACA5B1BFBC23467
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
in U I setting shows
IMEI: xxxxxxxxxxxxxxxxxxx, ASIC: 11
Writing SimLocks Failed: 14 BAD RSA SIGNATURE
SimLocks Init Failed
UI Defaults Ok, Time: 00:01
Set UI Factory Defaults Ok, Time: 00:00
Set Full Factory Defaults Ok, Time: 00:01
Set Software Upgrade Defaults Ok, Time: 00:00
Set Security Ok, Time: 00:00
Init Normal Mode Ok, Time: 00:02
pls help
Old 04-01-2013, 06:22   #2 (permalink)
Unlock Source's Avatar
Member: 1867175
Sonork: 100.1607600
Thanks Meter: 46
Hi brothers
I also have same issue in Nokia 101
IMEI: 359069-04-623764-2, ASIC: 11
UI Defaults Failed
Some 1 Please reply me
Old 05-15-2013, 13:18   #3 (permalink)
Member: 890328
Thanks Meter: 50
facing the same in nokia 1616 if anyone have solution please update thank full to all
Old 05-16-2013, 05:18   #4 (permalink)
Member: 1570550
ektapatel
Platform: Infineon
Prd.Code: 0595840
Bpr.Code: 059F8R0
Prod.Sn : 9683C76AI
HW Vers : 1014
UEM : 1328
UPP : 8850 [2292]
SL Aux : 000B0000
pls help
Old 05-31-2013, 16:01   #5 (permalink)
Member: 1887836
do we have to make a Downgrade or an upgrade to Unlock this phone
if some came up with a solution please Share
Page generated in 0.22563 seconds with 9 queries
