12-21-2013, 12:13 | #1 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | nokia x2-01 set off when incoming call????? 1-flashed from higher ver. 2-removed or changed ear speakar. 3-removed or changed headphone scoket. 4-cleaned pcb. 5- changed battery and sim. is any other solution too solve it with tested?? |
12-22-2013, 04:52 | #3 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: Pune (Daund) Maharashtra Age: 34
Member: 787710 Status: Offline Sonork: not using Thanks Meter: 771 | Quote:
The Following User Says Thank You to suraj9860607689 For This Useful Post: |
12-23-2013, 06:50 | #4 (permalink) | |
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Quote:
any other usefull advise. | |
12-23-2013, 08:19 | #5 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: Sri Lanka Age: 34
Member: 1615710 Status: Offline Sonork: 100.1647890 Thanks Meter: 260 | Quote:
according to my experience this fault comes from bad RF contacts. There for you must check RF parts of your set. If you properly done above steps try steps bellow one by one. 1. Reheat 2.Re solder 3.Replace ....,,,, RF IC.. if unsuccessful try following steps. BR. N.C.Erepola ..::SriLanka::.. Last edited by N.C.Erepola; 12-23-2013 at 08:25. | |
12-23-2013, 08:36 | #6 (permalink) |
Member: 1615710 Status: Offline Sonork: 100.1647890 Thanks Meter: 260 | sorry for the mistake before try above solution do this, to External antenna port. remove and apply jumper... if this unsuccessful try my first post's solutions BR. N.C.Erepola ..::SriLanka::.. |
10-20-2015, 08:39 | #10 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | X2-01 Turn off INCOMING CALLS SOLVED Thanks for usefull post , i flashed it with latest version then go to setting > profile setting > Vibration Alert = OFF the problem is Solved ,,,,,,,,, |
