Old 10-21-2014, 13:07   #1 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
nokia x2-01 user code problem<<<strange problem>>>>
first i want ti say those member who tell me solution.....please read carefull my post before reply. thanks.
i have set nokia x2-01 qwerty keypad in simple user code.
after power on mobile when i connect usb cable into mobile,a massage appear look it------ unlock security code to active usb....
it means set detect usb but it will work after unlock user code and for unlock user code we have to flash it or reset factory data.
therefore when i am trying to flash it set no boot ,no sence.
i tried from nokia best tool ,atf bo and hwk boxes but set not getting boot mode .
i need tested solution for expert who already faced this problem.
Old 10-23-2014, 21:11   #2 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Remove phone from USB Put it off !!
Start flashing put USB cable in the cellphone and check the result!
Br.
Old 10-25-2014, 07:23   #3 (permalink)
Member: 1722956
Thanks Meter: 305
Originally Posted by shakeel_pattoki View Post
remove phone from usb put it off !!
Start flashing put usb cable in the cellphone and check the result!
Br.
what about battery??? You dont write about battery condition?
Ithout battery or with battery.
By the way,i use all method for this mobile.
The main reason for problem is that usb work that time when user code will bbe unloaked. It means set does not accept usb unless user code removed.
Therefore i am unable to remove code.
Any other solution?
Page generated in 0.14048 seconds with 8 queries
