Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009 Location: mx-key is the best nokia tool.
Member: 1051835 Status: Offline Sonork: 100.1594332 Thanks: 193
| Nokia x2-02 Memory Card Not Formatted Solution.Please help me. |
| | #7 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2011
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks: 31
| How to Solve Memory Card Damaged : Memory Card (Memory Card) is an important part of a phone, whether it is mobile hi-end or low end, it all depends on the memory card for data storage media. Among the existing Memory Cards, MicroSD type is a lot dipake by many mobile phones available in the market. Well, what happens when you hang a memory card, but there saved a lot of files, such as songs and photos. The memory card that hangs there are many why, generally a problem often encountered in users who frequently remove and insert the memory card, usually for the purpose of transfer / copy data. But it could also be a problem caused by the influence of magnetic fields and heat. Damage the memory card is often called corrupt memory. This occurs due to damage to the file system, and not cause damage to the memory card physically. Indaksi from the corrupt memory content can not be detected or could not be opened. When you have problems like the above, steps can be taken in a way to format the memory card. Here are the steps to format the memory card correctly. Format a Memory Card using windows format Remove the memory card from the phone Actually in some phone are 'good manners' to take off (remove) the memory card, with the following instructions, the program is running on the phone will not crash. Symbian and Android phone is equipped with tools to remove the memory card. Insert the memory card into the card reader and connect it to the computer Find the memory card drive (see Windows Explorer menu), for example, on the drive (D, E, F, G, H or other). If the memory is read, click the right mouse button, and select the 'Format'. Next comes the choice of format (FAT, FAT32 and NTSC), make sure you select FAT file system format. Click the 'Format Now' and wait for it to finish. If the message 'error' then the PC can not format yet, use another way the format via Command Line menu. Format a Memory Card using the Command Line On the PC, click Start -> Run, and type CMD. Command window will appear in the DOS prompt mode. Next type FORMAT h: / FS: FAT (H = drive location of the memory card, if a memory card is located in drive g, then write g) Wait for it to finish. If the problem persists on the memory card, please use another memory card reader. But if it is not repaired, forced the memory card must be exchanged with the seller, if it is still under warranty. Keep in mind, before you buy a memory card, note the brand and collateral warranty. |
| The Following User Says Thank You to d-Artigo For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
