Old 05-07-2008, 09:42   #1 (permalink)
Member: 752277
Thanks Meter: 3
nokia 3110c ... always shows card not formated ...
nokia 3110c ... always shows card not formated ... when i format it ... it says card formated ... but when i open memory card again it says not formated ...
the mmc ic was broken & it was not shoiwing mmc ... so i changed it & now this is the problem ...
any one have the idea to get rid of this problem ?
The Following User Says Thank You to ashoka_ashok For This Useful Post:
Old 05-09-2008, 07:06   #2 (permalink)
Member: 752277
Thanks Meter: 3
thanks for not replying ... i have solved my problem by reheating the mmc ic again ...
Old 02-05-2009, 05:43   #3 (permalink)
gauravmobile's Avatar
Member: 725523
Thanks Meter: 26
nokia 3110c ... always shows memory card not formated 100% solved problem
mobile me 07.01 ver... ki felsh file kariye aur memory ko fat se format kar ke fir le load kar ke test kariye
100% ok test kiya huaaa jugaaaaaaaaaaaad
Old 02-05-2009, 15:26   #4 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
chang mmc ic your fone is ok
Old 02-08-2009, 14:23   #5 (permalink)
Member: 905012
Sonork: 003944
Thanks Meter: 63
3110c mamorey card not fromated
tri thies[IMG][/IMG]
The Following 7 Users Say Thank You to palash_mee For This Useful Post:
Old 09-19-2009, 09:28   #6 (permalink)
Member: 500885
Thanks Meter: 77
nice post thank you bro.....!
The Following User Says Thank You to m.bala For This Useful Post:
Old 01-05-2013, 07:45   #7 (permalink)
Registered User
Member: 1822996
not work probllame will be same plz help me 4 give me final solution
Old 01-05-2013, 08:22   #8 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Brother try to check these points and change the working MMC IC, the Post result...
3110c memory card not formatted bajji Nokia Hardware & Hardware Repair 8 04-14-2014 07:42
nokia 3110c charging show but not charging umesh garg Nokia Hardware & Hardware Repair 28 02-25-2012 12:48
3110c memory card not formated ashokassag Nokia Base Band 5 ( BB-5 ) 4 03-23-2010 11:44
nokia 3110c charging show but not save drjaved_akhter Nokia Hardware & Hardware Repair 3 06-17-2009 16:00
Page generated in 0.15816 seconds with 11 queries
