05-09-2012, 15:16 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: unlockprice.com
Member: 1263622 Status: Offline Thanks Meter: 149 | """nokia x2-05""" how to solved it ??????????any idea give me any sir ????????????? |
05-09-2012, 20:06 | #3 (permalink) |
Freak Poster Join Date: Sep 2009 Location: GPT partittions Age: 32
Member: 1119242 Status: Offline Sonork: 100.1638541 Thanks Meter: 121 | change power ways [IMG]http://2.bp.********.com/-wLx6K-aTfYE/T0NkU_Qs7zI/AAAAAAAAAwg/yY94-jCfaig/s1600/Power-Switch-ways.jpg[/IMG] |
The Following User Says Thank You to ms phone For This Useful Post: |
12-10-2013, 12:04 | #8 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | same problem here, nokia x2-05 was working fine only the browser was not opewning so after flashing the phone restart and hang, i removed camera buit not work card found: S/N 87A0:0122 registered to: fragga Connect phone on selected interface... IDM initializing, wait... Checking access to Products folder... Folder for RM-772 exist Prepare done, collect info [Query] : rm772__08.60.mcusw , 25.72 MB [Query] : rm772__08.60.ppm_c , 4.99 MB [Query] : RM772_059H0P2_08.60_032.vpl , 3.36 KB [Query] : rm772__08.60.image_c_059H0P2 , 13.59 MB Files to download : 4 Total size to download : 44.30 MB Downloading now, please, wait... [Download] : rm772__08.60.mcusw Core : v1.76 , BB5XG FlashEngine : v7.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm772__08.60a.mcusw PPM : rm772__08.60a.ppm_d CNT : rm772__08.60a_001.image_d_tele2_hr_9n8g1 Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 352420053643148 PCcode : 059M5J1 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352420053643148_XG 213_CRT.rpl ===Flashing [MCU]=== File : rm772__08.60a.mcusw Image : rm772__08.60a.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x018C0000 Erasing, wait ... Erase done, time : 00:02:16 Write , Start : 0x40280000 , Len : 0x01840000 Flashing , wait ... Region flash done, time : 00:00:36 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x053E ===Flashing [PPM]=== File : rm772__08.60a.ppm_d Image : package_d.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41B40000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:31 Write , Start : 0x41B40000 , Len : 0x0055527C Flashing , wait ... Region flash done, time : 00:00:07 CRC check passed , 0xE05B ===Flashing [CNT]=== File : rm772__08.60a_001.image_d_tele2_hr_9n8g1 Image : /build/rm772_sw_settings/temp/059N8G1/CONTENT_CONFIG/package_ Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42240000 , Len : 0x01BE0000 Erasing, wait ... Erase done, time : 00:04:17 Write , Start : 0x42240000 , Len : 0x00D20000 Flashing , wait ... Region flash done, time : 00:00:24 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x5DA2 Flashing done! Total flash time : 00:08:31 Reboot phone now... Reading Phone Info.... Connected phone - X2-05 Software Info: V 08.60a 27-12-11 RM-772 (c) Nokia IMEI: 352420053643148 PPM version : V 08.60a 27-12-11 RM-772 (c) Nokia D Product code: 059L9M1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:35 Connect phone on selected interface... [Download] : rm772__08.60.ppm_c Phone found! Series 40 Device detected! read info... - Ok |
sagem my-x2 unlocking codes...plz! | thecremeegg | Phone Unlocking Codes & Maps | 1 | 10-09-2003 20:38 |
Sagem My-x2,x6,g5 | nyonyo | Wanted Products | 1 | 09-18-2003 15:02 |
Solution for MY X2 | VINCECHRIS | Phone Unlocking Codes & Maps | 0 | 09-16-2003 06:57 |
Solution for MY X2 ???? | VINCECHRIS | ARM9 BASED M62 / M62+ | 2 | 09-15-2003 18:04 |
my-x2 unlock code ? | equinoks | Phone Unlocking Codes & Maps | 0 | 09-08-2003 13:09 |
