Old 07-05-2011, 12:31   #1 (permalink)
Member: 1610374
Exclamation Nokia X3-00 RM-540 Reset
hi
x3-00 rm-540 new brand
reset some times after 5 second or sometimes reset after some hour .
Things I've done for solve this problem :
1-change lcd
2-change flex cable
3-service phone with ultra sonic
4-replacement PEARL IC
5-Heating On Flash and CPU IC
6-flash with usb : MT and MX-KEY
7-TEST WITHOUT CAMERA
mt usb flashing LOG :
Processing File:  rm540__11.00.mcusw
Boot...
CONNECT PHONE to USB and Power ON phone!
Pooling for phone...
\\?\nmwcd#vid_0421&pid_0106&if_oth#6&1956a86f&2&00#{4f919102-4adf-11d5-882d-00b0d02fe381}
RAP3Gv40_2nd.fg
Sending ULO code
RAP3Gv40_XSR17_alg.fg
Pooling for device removal...
Pooling for ADL device...
Erase[121.38 MB]...
erasing RAP [00020000 to 000203FF]
erasing RAP [00060000 to 0009FFFF]
erasing RAP [000A0000 to 0025FFFF]
erasing RAP [003E0000 to 005DFFFF]
erasing RAP [005E0000 to 010DFFFF]
erasing RAP [01EC0000 to 01EDFFFF]
erasing RAP [027C0000 to 02CBFFFF]
erasing RAP [077C0000 to 07B3FFFF]
erasing RAP [010E0000 to 01EBFFFF]
erasing RAP [02CC0000 to 077BFFFF]
erasing RAP [01EE0000 to 027BFFFF]
in 1.16s
Flash[26.13 MB]...in 31.39s
* * Processed file in 60.81 seconds
Processing File:  rm540__11.00.image_meac_0584363_008
Boot...
Erase[0.00 MB]...
in 0.00s
Flash[17.38 MB]...in 21.28s
* * Processed file in 21.31 seconds
Processing File:  rm540__11.00.ppm_meac
Boot...
Erase[0.00 MB]...
in 0.02s
Flash[5.31 MB]...in 6.45s
* * Processed file in 6.48 seconds
Restarting device...
Device disconnected.
* * * Phone flashing done in   1:29 minutes
 Post Flash serial tunning of phone....
Pooling mode for full factory set...
V 11.00/17-03-11/RM-540 (c) Nokia
    IMEI: 354865043624988
Factory Default Settings...OK
MX-KEY USB FLASHING LOG:
MXKEY Serial: [FT SCR2000 0] - C080C64B
Driver: NMWCD, ver: 7.1.32.62, NTMP ver:
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
Processing MCU file: rm540__11.00.mcusw
 [BB5,XSR 1.6]  size: 26.13 MB
 Supported Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1956A86F
CMT SYSTEM ASIC ID: 000000010000022600000001020C192102054100 [RAPS2 ver: PA 4.x]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 0F90021816235440862CA12F2EE5EEC3B837338A
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT ROM ID: 67E82268F29CEA60
Loading CMT secondary boot code
 SecondaryBoot: RAP3Gv40_2nd.fg [BB5]  version: 10.22.0 revision: 3.0 size: 0x3B40
 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
Secondary boot loaded.
FlashID0: 0000 0000  - 0000 0000 [unused/removed] type: NOR,CMT
FlashID1: 0000 0001  - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 00EC 0030  - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT
ALG [35]: XSR 1.6
Loading CMT update server data
 Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6]  version: 10.22.0 revision: 3.0 size: 0x8F9A0
Update server code loaded.
Verifying communication to device OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35486504362498_CERT.rpl"
CMT PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E
Storing certificate [NPC, CCC, HWC, R&D]  OK.
Partitioning....
Partitioning complete
Erase size: 37.69 MB
CMT MuxOneNAND area [00020000-000203FF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500626C6F (RAP Certificate 193 v.1) sent
CMT RAP3NAND block sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 55.079 s
Processing PPM file: rm540__11.00.ppm_meac
 [BB5,XSR 1.6]  size: 5.31 MB
Erase size: 8.87 MB
CMT MuxOneNAND area [01EE0000-027BFFFF]
Programming completed in 11.187 s
Processing CNT file: rm540__11.00.image_meac_0584363_008
 [BB5,XSR 1.6]  size: 17.38 MB
Erase size: 75.06 MB
CMT MuxOneNAND area [02CC0000-077BFFFF]
Programming completed in 36.640 s
Total time for flashing process(boot+erase+write) was 2 min 3.859 s
Waiting for device boot up ...
Device found: nmwcdc\Nokia X3 USB Phonet, PORT_ID: 112EB984
Phone Type: RM-540 (Nokia X3-00)
SW Version: V 11.00 17-03-11 RM-540 (c) Nokia
Imei plain: 35486504362498-8
Product Code: 0583979
Battery voltage: 3794 mV, current: 91 mA
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354865043624988
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Market items is empty, please select the corre
Security LOG MX_KEY:
SIMLOCK_TEST passed
Counter: 0/3, 0/10
BUT PROBLEM NOT SOLVE
PLEASE HELP MEEEEEEEEEEEEEEE
THX
Old 07-05-2011, 16:01   #2 (permalink)
Member: 1610374
please help meeeeeeeeeeeeeeee masters
Old 07-05-2011, 20:22   #3 (permalink)
snmobilecenter's Avatar
Member: 983663
Sonork: 100.1623270
Thanks Meter: 551
Its like hardware problem:- check battery, battery conection, and battery pin, also try with your external power supply then check board............. don't touch any ic first
Good luck
The Following User Says Thank You to snmobilecenter For This Useful Post:
Page generated in 0.16408 seconds with 9 queries
