06-26-2013, 19:58 | #6 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,349 | look , in X3-02 not much parts used for key function . key way goes from keypad esd filter to rapuyama . so some primary instruction should be taken , such as clean whole pwb , check or clean volume + & - key also lock key , replace good quality keypad esd filter . make sure keypad esd filter soldered well . if needed resold keypad ui connector . if still same after doing this then u need to reflow or reball rapuyama ic D3000 . post result |
06-27-2013, 11:22 | #7 (permalink) |
Crazy Poster Join Date: Aug 2005 Location: Portugal
Member: 166565 Status: Offline Thanks Meter: 3 | i´ve changed 4 IC filter and nothing, second remove volume up, down and lock buttons and after rehot D3000, but nothing still the same. in the keypad only works button on/off |
06-27-2013, 11:51 | #8 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Ghaziabad, India
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | check each n every inner with its outer key if it short one by one.... any key is short with ground or inner is shorted with its outer.... check once again with deep..... |
06-27-2013, 13:48 | #10 (permalink) |
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | I have no doubt on keypad flex.... i want to sure that all the tracks are in ok condition or not which are coming from pcb.. may be connector is short... or any component is liable for not working the keypad.... so, check properly... |
06-27-2013, 14:55 | #11 (permalink) |
Member: 166565 Status: Offline Thanks Meter: 3 | so you're sayng to remove the ic filter and check the continuity like the image in the link ? http://4.bp.********.com/-HgRqtymrqw...s+solution.jpg |
06-28-2013, 16:01 | #15 (permalink) |
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | As I show in image. Check with multimeter on beep. If multimeter give some value then that key is in working condition, check each key one by one like this. If during this process, any key gives beep sound, it means that key is short. then check the track of that key properly........ |
